Schleprock Struck!
Old Apr 27, 2003 | 05:38 PM
SBNova's Avatar
SBNova
Default Re: Schleprock Struck! (ski_dwn_it)
You may just need a better fuel pump. I cant beilieve your running the stock one. Your stock pump may not be able to push a column of fuel forward under the starting G's without a half tank or greater ( its harder to push rearward when the tank is full- it has the weight of "x"-gallons behind it). ANother option is an external pump and sump your stock tank. I know many have preached the dont weld to a stock tank story. I have personally sumped two used tanks. Just empty them, flush em with water and let them sit a while. I tig my sumps on and they work great. Nothing like sucking fuel right off the rear bottom of the tank.
Old Apr 27, 2003 | 06:17 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Schleprock Struck! (SBNova)
Again, I am 99% sure its fuel level related and not fuel supply problem, since I can keep an Air/fuel ratio of 12.8 on my WB02. That tells me that the fuel is being supplied as long as the fuel LEVEL is high enough to keep the pickup covered. :cheers:
Old Apr 27, 2003 | 09:37 PM
jimmyd's Avatar
jimmyd
:thumbs: Good times,
get the rev limiter hooked up !
I had to run a larger size line on my other car. (not a vette)
