head plug??
Old Apr 26, 2003 | 01:12 PM
devilfish's Avatar
devilfish
Default head plug??
The little "Plug" that sits on the end of the block up against the cylinder heads ( the ones that is rasied ), is that just to help guide the heads and gasget when you mount the heads? Or is doing something else??
thanks
[Modified by devilfish, 7:25 PM 4/26/2003]
Old Apr 26, 2003 | 01:32 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: head plug?? (devilfish)
Are you talking about that stud?? If so, then yes, its purpose is to 1) hold the gasket in place, 2) hold the head in place, while you tighten it.
Old Apr 26, 2003 | 01:36 PM
devilfish's Avatar
devilfish
Default Re: head plug?? (MarkLT1)
yepp that is the one.. Does it do annything special but 1) hold the gasket in place, 2) hold the head in place, while you tighten it?? It does not block any oil path or something vital?
Old Apr 26, 2003 | 01:41 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Not that I know of, but I wouldnt try to put a set of heads on without it. And it might be blocking some coolant path, but I dont think so.
Old Apr 26, 2003 | 01:48 PM
devilfish's Avatar
devilfish
yeah I did. I lost 2 of min during the take off my old heads. So I used only 1 plug on each side. Im not affraid of the head be missalign in annyway, but. Im more affraid that its also there for som other reason.. :(
Old Apr 26, 2003 | 01:51 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
If I remember correctly, the stud just goes into a hole in the head that goes nowhere.. thus, at least on the LT1, I dont think it is blocking off any kind of passage, so you should be OK.. but hopefully someone can chime in and tell you for sure.
Old Apr 26, 2003 | 01:53 PM
devilfish's Avatar
devilfish
hm ok thanks...
Old Apr 26, 2003 | 02:01 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
BTW: How did you manage to lose 2 of them? Mine are in the block so hard, they were going nowhere...
Old Apr 26, 2003 | 02:02 PM
devilfish's Avatar
devilfish
min followed the heads, and then fell off som where??
Old Apr 26, 2003 | 05:32 PM
devilfish's Avatar
devilfish
ttt
Old Apr 26, 2003 | 05:37 PM
scorp508's Avatar
scorp508
Leave them in there, they don't harm anything. They are there to hold stuff in place to make it a hell of a lot easier to install.
Old Apr 26, 2003 | 05:41 PM
devilfish's Avatar
devilfish
Default Re: head plug?? (scorp508)
yeah i know but i have already installed my heads without the 2 off the "pins". Im I ok?? :banghead:
Old Apr 26, 2003 | 06:50 PM
devilfish's Avatar
devilfish
tt
Old Apr 26, 2003 | 07:56 PM
scorp508's Avatar
scorp508
You should be fine to the best of my knowledge. I'm pretty sure that the dowels go into blind holes in the heads and that if you pull the dowels from the block they are blind holes also.
Old Apr 27, 2003 | 05:00 AM
devilfish's Avatar
devilfish
ahhh ok ;)
Old Apr 27, 2003 | 05:41 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
These dowel pins make sure the heads are in exactly the correct position on the block and keep the heads from moving around and help make sure the intake is aligned.
Old Apr 27, 2003 | 08:41 AM
devilfish's Avatar
devilfish
Default Re: head plug?? (Mez)
yepp I know. I used 1 pin on each head, cause I lost the other 2 :( But should I be OK with this?? I whas very carful with the alignment. im more worried about if they block anny coolant or oil path?
To head plug??
Old Apr 27, 2003 | 09:09 AM
Mez's Avatar
Mez
I don't think you have anything to worry about. They are not connected to the oil or coolant system.
Old Apr 27, 2003 | 09:37 AM
devilfish's Avatar
devilfish
ok :) thanks
Old Apr 27, 2003 | 01:37 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
I thought about this a bit this morning devilfish-
I dont know if I would try to install the heads without 2 pins on each side. Those heads need to be aligned PERFECTLY, otherwise you are going to be tearing it down again for a blown head gasket. I know that the head bolts have a little lateral slack in them (they dont totally fill the hole in the head..), which would let you move the head slightly while installing. Not a good thing. I would try to find the old ones, if not, pull one of the remaining pins, and go get something of the same size. Just my 2 cents.
