Window problems. need help.
Old Apr 26, 2003 | 11:41 PM
sebvette's Avatar
sebvette
Default Window problems. need help.
My passenger window on my 92 vette makes a banging niose if the window is down just a bit. Sounds like the glass is going to break if the door is slamed to hard. Its fine if the window is up. What do I need to fix this?
Thanks everyone!
Old Apr 26, 2003 | 11:50 PM
bogus's Avatar
bogus
Default Re: Window problems. need help. (sebvette)
scary, ain't it.
mine does the same thing.
I think there are these little pads that the window rides on, and they wear out.
where in sebring are you? my brother lives in lake placid! he owns Bogus Printing - go figure.
I go down for the 12 hours every year!
Old Apr 26, 2003 | 11:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Most likely the felt pad has come off the arm that pushes the window into the weather strip.
Pull the door panel and check it out.
Old Apr 26, 2003 | 11:54 PM
sebvette's Avatar
sebvette
Default Re: Window problems. need help. (bogus)
Cool! I went to the races this year too. Go Corvette! I live behind Harder Hall in Sebring. Let me know if you know what pads those are we need to fix the problem.
Thanks!
Old Apr 27, 2003 | 01:26 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Most people complain about the same thing. Adjusting the pads may help but it didn't when I replaced the outer window W/S. Still sounds like the glass is gonna break. :yesnod:
Old Apr 27, 2003 | 02:27 AM
JCAIRE2's Avatar
JCAIRE2
Default Re: Window problems. need help. (Blue 92)
You probably need a set of these http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763 :cheers:
To Window problems. need help.
