[UPDATE] Dissapointing Track Results
Old Apr 27, 2003 | 12:00 PM
Squareseven's Avatar
Squareseven
Default [UPDATE] Dissapointing Track Results
Well, this is the stupidest outcome! :crazy:
Sure enough, just as datamaster said, i was only getting 65% throttle!
There is some slack in the cable and when i push down the throttle, the body only opens up partally! :smash: :smash: :smash:
Now, does anyone know how to adjust the cable?
Old Apr 27, 2003 | 12:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: [UPDATE] Dissapointing Track Results (Squareseven)
On my 94, the accellerator cable adjusts going to the ASR. Pull up on the cable adjuster, stretch the cable to adjust, and then snap the adjuster clip back down.
I had the same problem on my car after changing throttle bodies. It was a nice surprise when I realize that it wasn't going to WOT. Just an easy adjustment, and an instant horsepower increase.
Old Apr 27, 2003 | 12:22 PM
Lone Ranger's Avatar
Lone Ranger
Its super easy, standby I will post a pic of the throttle cable adjuster that is on my '95... gotta find the pic i took of it last year...be just a minute and will post it...
Old Apr 27, 2003 | 12:27 PM
Hole-Shot's Avatar
Hole-Shot
Default Re: [UPDATE] Dissapointing Track Results (Lone Ranger)
:thumbs:
Old Apr 27, 2003 | 12:29 PM
Squareseven
Thanks! :cheers:
Old Apr 27, 2003 | 12:31 PM
Lone Ranger
Here it is, hopefully the pic will show but lately the forum hasn't been doing well showing pics in the post, only show's 'em in sigs.
push the button in and pull the cable carrier to right (toward back of car) to tighten or remove slack. Push button and shove the cable carrier left (into the adjuter) to add slack or loosen the throttle cable.
pic (hopefully):
Old Apr 27, 2003 | 12:37 PM
Squareseven
pic (hopefully):
Yup, pic works! That was SUPER easy! :cheers:
Time for a test drive :D
Old Apr 27, 2003 | 01:03 PM
Squareseven
Well, she's better now! I took it for a short ride and got on it a few times. Seems to have a bit more power! Time to go to the track again though to find out! :reddevil
Now, off to home depot to get some touline :jester
Old Apr 27, 2003 | 02:07 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Good job Squareseven! :cheers:
Old Apr 27, 2003 | 03:41 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: [UPDATE] Dissapointing Track Results (JimmyS5600)
Better times will surely follow. Still need to get rid of that timing retard problem though. I don't know what can be causing it to retard the timing without seeing any knock, might try that LT1 knock module again.
:cheers:
To [UPDATE] Dissapointing Track Results
