Quick Air Tool Question??
Old Apr 27, 2003 | 10:24 PM
CG77VETTE's Avatar
CG77VETTE
Default Quick Air Tool Question??
I apologize, I didn't know where to post this question. I would just like to know if a compressor with a 2 lb. tank and max 125 psi will operate air tools.
Old Apr 28, 2003 | 12:31 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Quick Air Tool Question?? (CG77VETTE)
I don't know. I think it's to small to run a dual action sander but this will get you ttt.
Old Apr 28, 2003 | 08:21 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
How many gallons does a 2LB tank translate to? I ran a die grinder off a 4 or 5 gallon (I think) Cambell Housfeld. I would have to wait and let the tank fill up ever minute or two though with continuous use. I now have a 80 gallon Craftsman that has no problem keeping up with anything I throw at it.
Old Apr 28, 2003 | 08:26 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
The lower storage capacity is good for short burst tools (nailers). If you're going to use impact wrenches, air ratchets, etc., I'd get at least a 20 gallon tank. That's what I use and when using the ratchet, it kicks on quite often but I'm never waiting on it.
Old Apr 28, 2003 | 08:40 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Quick Air Tool Question?? (ShawnZR-1)
I think it depends more on the air flow the compressor can maintain.
My 21 gallon works will.
Old Apr 28, 2003 | 08:47 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Storage tank and PSI are not the only questions, which I have learned to my chagrin. Compressor CFM is most important. I am looking to move up to atleast a 15cfm to support air tools without having to stop to wait for compressor to catch up
Old Apr 28, 2003 | 09:32 PM
froggy47's Avatar
froggy47
Tools like air hammer & ratchet yes, grinder and other more continuous stuff , the rpms will eventually slow down & you have to wait. I have one & it's ok for weekend stuff but would not use it for hard core job or daily use. Got at Costco.
To Quick Air Tool Question??
