L98 Cam / Valve Spring Question.
Old Apr 28, 2003 | 11:48 AM
CAJUN C4's Avatar
CAJUN C4
Default L98 Cam / Valve Spring Question.
Building an 87' L98 have Allum. "D" port heads Question: I'm running the ZZ4 Cam has .510" Lift on ex side. Can I use the stock Valve Springs.?If not. Anyone have springs for sale that will work?
Old Apr 28, 2003 | 11:53 AM
scorp508's Avatar
scorp508
Default Re: L98 Cam / Valve Spring Question. (CAJUN C4)
No you cannot use the stock springs. TPiS has springs they prescribe for all of their cams.
http://www.tpis.com/CatalogPages/CatalogPage.ASP
Goto page 50.
[Modified by scorp508, 11:54 AM 4/28/2003]
Old Apr 28, 2003 | 05:56 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
Default Re: L98 Cam / Valve Spring Question. (scorp508)
Quote
'No you cannot use the stock springs. TPiS has springs they prescribe for all of their cams. http://www.tpis.com/CatalogPages/CatalogPage.ASP
Goto page 50.'
:iagree:
Check your valve retainer clearance as well. !!! :)
[Modified by Davemc1963-87conv, 10:59 PM 4/28/2003]
Old Apr 29, 2003 | 09:48 PM
1MoorTym's Avatar
1MoorTym
Add another no to stock springs. Since you're using a ZZ4 cam on the alum 113 heads, why not use the entire valve train as the ZZ4.
GM sells it all. If you need p/n's let me know.
Old Apr 29, 2003 | 11:57 PM
Z-PDX's Avatar
Z-PDX
Default Re: L98 Cam / Valve Spring Question. (1MoorTym)
Are you planning on using stock chip?
Any recommendations for good chip to work with ZZ4 cam?
-Z
Old Apr 30, 2003 | 09:41 AM
CAJUN C4's Avatar
CAJUN C4
I was planning on getting the ZZ4 GM Springs.p/n:12495494 as a kit of 16 @ #12551483.springs.? 101#'s @ 1.78" ?
sound right?
Old Apr 30, 2003 | 09:43 AM
CAJUN C4's Avatar
CAJUN C4
Default Re: L98 Cam / Valve Spring Question. (Z-PDX)
Dino... Not quite there yet..I have a Hypertech stage 2 in it right now. Probably go with the 7747 ECM.
Old Apr 30, 2003 | 05:59 PM
1MoorTym's Avatar
1MoorTym
sound right?
Yep, thats them. Also get the following
10212809 - Va;ve Spring Shim LT4
12495492 - Valve Spring Cap Kit LT4
12495503 - Valve Spring Keys
The cam will run fine with the stock chip, it might be a little choppy in open loop but then it settles down. I'm getting ready for a chip now, but I've already went with a ported plenum, big mouth base and large tube runners.
Old Apr 30, 2003 | 07:05 PM
Davemc1963-87conv
You need to check the size of the spring seats on your heads.
As far as I am aware, most early L98 heads (113 & 128) only had 1.25" spring seats. the same as ZZZ-ZZ2 engines. Later heads had the 1.32" (ZZ4/LT4) spring seats. Can anyone else confirm this?
Old Apr 30, 2003 | 07:28 PM
1MoorTym's Avatar
1MoorTym
Default Re: L98 Cam / Valve Spring Question. (Davemc1963-87conv)
Aluminum 113 Heads do have 1.32 spring seats. Its the head the ZZ4 uses as are all the components previously listed. Is the 128 an iron head ?
To L98 Cam / Valve Spring Question.
