exhaust manifold leak
Old Apr 28, 2003 | 12:50 PM
luck38's Avatar
luck38
Default exhaust manifold leak
can an exhaust manifold leak cause the idle to be high. I have no vacuum leaks and i reset the computer and adjusted the idle the correct way but it is stuck at 11 in park and about 8 in drive with the break on. The only apparent problem is the manifold leak. Also, every once and a while when the car is pushed hard i get a check engine light on and the idle goes back to normal (is this the "limp home mode"?). When i shut the car off and restart it the idle is high and the check engine light is off.
Old Apr 28, 2003 | 01:09 PM
ittlfly's Avatar
ittlfly
Default Re: exhaust manifold leak (luck38)
Have you pulled the code from the "check engine light"?
Old Apr 28, 2003 | 02:14 PM
luck38's Avatar
luck38
Default Re: exhaust manifold leak (ittlfly)
does the compure store codes or do i need to pull it when it is on?
Old Apr 28, 2003 | 03:35 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
it stores them.
Old Apr 28, 2003 | 05:59 PM
ittlfly's Avatar
ittlfly
Look up 65Z01 website here on the forum. He has outlined the proceedure for extracting the code(s) from the ECM. After you get the codes, post the results and we'll see where we are.
Old Apr 29, 2003 | 07:44 AM
luck38's Avatar
luck38
thanks, i will refer to the site and then let you guys know the code. I appreciate it.
Paul
Old Apr 29, 2003 | 08:05 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:nonod:
Old Apr 29, 2003 | 08:26 PM
luck38's Avatar
luck38
ok here we go, i received the following on,on,off,on which i guess is 21, if so that would be throttle position sensor out of range (i hope i deciphered it correctly), then i got on, on, off, on,on (22?) throttle position sensor circuit voltage low, lastly i got on,on,on,off,on,on (32?) egr circuit fault. Could someone please tell me if i deciphered these correctly, and if these would cause a high idle?
To exhaust manifold leak
