Front main seal replacement: Pull timing cover or not?
Old Apr 29, 2003 | 08:03 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Front main seal replacement: Pull timing cover or not?
Haynes manual says to pull timing cover, some posts in archives say otherwise, Helms manual is still in the mail.
What do you think, is it necessary or preferrable to pull the cover? Should I do it anyways to check/replace timing chain?
:lurk:
Old Apr 29, 2003 | 09:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Front main seal replacement: Pull timing cover or not? (CentralCoaster)
I would pull the cover. Its easy to screw up a seal working in tight situations.And i you said you can inspect chain.For the cost of a new chain,i would put a new one in there.You sure are keeping busy lately.It must be hard fitting in school between all that vette work.I hope you start enjoying her again real soon!! Good Luck!!! :cheers:
One more thing,take a good look at the balancer for wear from seal.I have had to sleave others in the past due to seal leaving a ring in it.
That should be my last edit!!! DOOOOOH!!!!
[Modified by AGENT 86, 6:52 AM 4/29/2003]
[Modified by AGENT 86, 7:07 AM 4/29/2003]
[Modified by AGENT 86, 7:09 AM 4/29/2003]
Old Apr 29, 2003 | 10:01 AM
ciscokid's Avatar
ciscokid
I second what Agent 86 stated. Good advice.
Old Apr 29, 2003 | 10:08 AM
scorp508's Avatar
scorp508
Default Re: Front main seal replacement: Pull timing cover or not? (ciscokid)
I would feel far more comfortable installing that seal on the bench instead of fighting with the crossmember and everything else down in that area. You want to make sure you tap the new seal in as evenly as possible.
Old Apr 29, 2003 | 10:14 AM
ittlfly's Avatar
ittlfly
Default Re: Front main seal replacement: Pull timing cover or not? (scorp508)
:iagree:
That way you can support the cover from underneath by a block of wood while installing the seal straight on the top side. Alos, might as well replace the other 2 seals too while it's on the bench.
[Modified by ittlfly, 7:15 AM 4/29/2003]
Old Apr 29, 2003 | 10:57 AM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: Front main seal replacement: Pull timing cover or not? (ittlfly)
I installed mine without pulling the timing cover. If you feel the need to inspect the timing chain and gears ~ then you have your answer ~ but if you just want to get rid of that flippin oil leak quickly with the least amount of hassle ~ then buy a seal puller (less than $10.00), pull the old seal (mine was brittle), and tap in a new one.
If the old seal was brittle ~ then most likely it has worn a groove on the balancer shaft. If so, buy a Speedy sleeve and tap it over the shaft. The speedy sleeves are made of polished Chrome-moly and make for a tight seal.
~ Purp :steering:
Old Apr 29, 2003 | 12:20 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Another option! ! ! ! !
What I did last time I had the water pump and opti off, I cleaned the area very good then applied black silicone around the shaft. It was days before I turned the engine over so it had time to set up.
I havn't seen a drop for several months now.
I know what you're all saying, of course that won't last very long but at least I postponed the hassle for awhile....
Just a thought.
:lurk:
Old Apr 30, 2003 | 05:37 AM
CentralCoaster
Default Re: Front main seal replacement: Pull timing cover or not? (AGENT 86)
I suspect I'll find wear on the balancer, but not sure how to judge what is acceptable. I bought both timing gasket kits, and will just return which one I don't use. One comes with the repair sleeve you were talking about. As far as timing chains go, should one of these cheapo $10 Kragen ones do the trick? Or would I be better off depending on the one that's already in there with a measly 60,000 miles on it. Napa has an edelbrock set for $60 including gears, but I don't wanna spend that much. How much slop is acceptable in the timing chain?
Thanks for your help! I wonder if I can send out beer certificates when this is all done. :lol: :cheers:
[Modified by CentralCoaster, 2:44 AM 4/30/2003]
Old Apr 30, 2003 | 09:06 AM
AGENT 86's Avatar
AGENT 86
If you see a groove,sleeve it!! If your chain has 60,000 on it and a chain costs 20 bucks,put in a new chain.
Old Apr 30, 2003 | 05:50 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
As far as the groove is concerned ~ if you can feel it with your thumbnail ~ then install the sleeve. Be carefull when installing the sleeve. You don't want to bend it. Installing the sleeve requires more effort than just sliding it over the balancer hub snout. As far as I'm concerned ~ there are two options for installing the sleeve:
1. Take it to a machine shop (NAPA Auto) and have them press it on.
2. (I do this) Lay a 2x4 on a solid surface
* Apply a light coat of silicone on the inside of the sleeve (it provides lubrication)
* Place the sleeve on the 2x4 (open end up)
* Align your balancer hub over the sleeve and tap it into the sleeve with a mallet. The sleeve should slide all the way on, don't leave any hanging over the end.
If you already have the timing cover off ~ replace the chain. In fact, pay close attention to the cam gear and if it shows wear, replace it too.
~ Purp :steering:
Old Apr 30, 2003 | 05:59 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: Front main seal replacement: Pull timing cover or not? (PurpleC4)
~ Purp :steering:
Where do you get a sleeve?? I'm doing this repair this weekend. Thanks :cheers:
Old Apr 30, 2003 | 06:39 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Default Re: Front main seal replacement: Pull timing cover or not? (94vette)
94vette,
You can get them at most any Auto Parts store. If you can wait until you can get the balancer off ~ it helps to take it with you and match the sleeve to the shaft diameter. Sometime the stores handle more than one brand ~ so I like to compare. Some call it a balancer repair sleeve ~ I have heard others refer to it as a Speedy Sleeve.
Remember that the sleeve is a very close tolerance fit.
~ Purp :steering:
Old May 1, 2003 | 05:29 PM
YLO Z06's Avatar
YLO Z06
Muchos gracias, Senior Stan :cheers:
Old May 1, 2003 | 11:11 PM
Siveck's Avatar
Siveck
I've heard that the kit is called a "sleeve and seal" kit. Do it, because my '92 Yukon leaks like a sieve (sp?) because I didn't use the kit.
Old May 2, 2003 | 08:20 AM
CentralCoaster
Default Re: Front main seal replacement: Pull timing cover or not? (Siveck)
Yup, sleeve n seal is correct. I haven't put it on yet, but I think I will.
I replaced the nylon cam gear with a steel one. That front main seal was a PITA to remove! It was seized in the cover good. I kinda bent the cover there, even with supporting it while trying to tap the seal out. Hopefully I can get it back to where it was.
To Front main seal replacement: Pull timing cover or not?
