Throttle Body Bypass?
Old Apr 29, 2003 | 10:16 AM
94 Red Roadster's Avatar
94 Red Roadster
Default Throttle Body Bypass?
I'm about to undertake a few HP mods. Looking at tb bypass. It doesn't make sense to me. Even if you disconnect the coolant hose isn't the heat of the engine block going to be transferred directly to the throttle body? In fact the coolant connection may actually reduce the heat at the tb. The engine block is hot metal and it's heat will be directly transferred to the throttle body. What am I missing here?
Old Apr 29, 2003 | 11:05 AM
grumpyvette's Avatar
grumpyvette
Default Re: Throttle Body Bypass? (94 Red Roadster)
what your missing! is about 5 hp if you DON,T do the MOD, WHY it works is that the air flowing thru the throttle body absorbs heat at a faster rate than the engine block can transfer it to the intake,
heres how to do the mod correctly
http://www.thirdgen.org/newdesign/te...ntbypass.shtml
heres how to make it look good
HERES PROOF IT WORKS http://www.ws6.com/mod-8.htm
[Modified by grumpyvette, 4:10 PM 4/29/2003]
Old Apr 29, 2003 | 11:37 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
In the stock configuration, hot air is blown into the throttle body to prevent freezing in extremelt cold conditions. You don't want this b/c the hot air robs HP. This isn't a mod that you're going to 'feel' the difference, but hey 5 hp and it takes a half hour to do, and cost me .50 for two hose clamps :chevy
Old Apr 29, 2003 | 11:40 AM
vader86's Avatar
vader86
Some heat will conduct up to the intake and plenum of course, but it wont be so hot that you cant touch it, and it is if you leave the coolant routed thru the TB. Coolant would actually act as a heat source to directly send engine heat to the TB, which heats up the intake air.
Old Apr 29, 2003 | 11:58 AM
Timmy!'s Avatar
Timmy!
Default Re: Throttle Body Bypass? (grumpyvette)
:withstupid: I guess I didn't realize that people actually cut that piece off. I thought people just plugged the hoses.
Old Apr 29, 2003 | 12:03 PM
krivera's Avatar
krivera
Default Re: Throttle Body Bypass? (Timmy!)
Timmy...i agree i just plugged the holes...keep it short and sweet! seems to work fine for me?
Old Apr 29, 2003 | 12:04 PM
Strick's Avatar
Strick
I didn't cut the piece out, I just put pugs that fit just right over the nipples (can I say that?)
:flag :flag
Old Apr 29, 2003 | 12:05 PM
krivera's Avatar
krivera
Default Re: Throttle Body Bypass? (Strick)
:withstupid:
Old Apr 29, 2003 | 05:27 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
QUOTE]I didn't cut the piece out, I just put pugs that fit just right over the nipples (can I say that?)
:flag :flag [/QUOTE]
Uh-oh, an X-rated post, forgive him Mr. Mojo for he know not what he do...
:lolg: :lolg: :lolg: :lolg: :lolg:
Old Apr 29, 2003 | 05:42 PM
Lone Ranger's Avatar
Lone Ranger
I hope you guys are just talking about putting covers over the coolant fittings on the tb, because plugging the steam tube that runs along the passenger side LT1 valve cover is a big no-no. It is the steam tube that the short elbow rubber hose that comes off the tb on the passenger side connects to. The steam tube collects coolant and vaporized coolant from the heads and sends it through the tb and it eventually is routed back into the pressurized holding tank. This steam tube concept brings to mind a question I have about the tb coolant bypass mod and how it may effect recovery of vaporized coolant. The mod is so widespread I'm sure it is harmless, but I may post a topic about it anyhow.
Old Apr 29, 2003 | 07:02 PM
ckgunn's Avatar
ckgunn
:lol: :lol: :lol: :lol: :lol: :lol:
Old Apr 29, 2003 | 07:58 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Just did the plugs too . . . hadn't even seen anyone cutting this section off the TB.
Old Apr 30, 2003 | 01:13 PM
sumoboy's Avatar
sumoboy
The LT1 has strategically placed steam vents at the back of both cylinder heads. Since the heads are the hottest part of the engine, pockets of steam can be more easily generated there. The steam vents are connected together by a crossover vent tube at the back of the heads, which directs any steam and a small flow of coolant to the front of the engine where it flows through the throttle body, warming it for improved cold weather performance. After passing through the throttle body, most of the steam is condensed back into liquid coolant and returned to the system.
http://www.theherd.com/articles/lt1_cool.html
Old Apr 30, 2003 | 04:24 PM
rubyred93's Avatar
rubyred93
Default Re: Throttle Body Bypass? (sumoboy)
Okay, what exactly did you guys plug the TB tube openings with after you connected the hoses? :confused:
Old Apr 30, 2003 | 05:14 PM
Lone Ranger
Default Re: Throttle Body Bypass? (rubyred93)
I thought most people just used a silver or black plastic cap on the end of each tb coolant fitting...question is, where to find such caps?
Old Apr 30, 2003 | 09:21 PM
Dark-Knight's Avatar
Dark-Knight
I plugged the TB holes with Red caps, looks cool. Matches the wires.
Old Apr 30, 2003 | 09:26 PM
Lone Ranger
Default Re: Throttle Body Bypass? (Beautiful Beast)
Beast, I have a question about your mods (sig). You have a 52mm tb which most have integrated airfoil in the design. You mention airfoil with the MAF... do you have an airfoil infront of the MAF? That would seem to make sense as mod-- to shape and concentrate the airflow over the MAF wires. I was just wondering.
Old May 1, 2003 | 02:42 AM
SUPERNINJAB0Y's Avatar
SUPERNINJAB0Y
Default Re: Throttle Body Bypass? (Lone Ranger)
great mod for 5 hp or so.u can feel your tb after an hour of town drivin and it wont' be hot! when i took my tb off i brought it in to kragen and matched up the ends with rubber block offs.only about 2 bucks for a pack of.....2! check it out,dont' leave em open for elements to be wandering in the tb.might not hurt it ,but ,just to be safe block em off.do that and other free mods pic up a tenth or two and be happy.
Old May 1, 2003 | 11:31 AM
kittmaster's Avatar
kittmaster
Where did you get these caps from? I'd like to cover up my holes also......thanks
To Throttle Body Bypass?
