Synthetic ATF
Old May 1, 2003 | 07:49 PM
RUSS105's Avatar
RUSS105
Default Synthetic ATF
I'm looking to put schaffers in my tranny, but my mechanic said that i'd need to flush the trany first. Is this the real deal or can it be poured in with the regular? :confused:
[Modified by RUSS105, 7:49 PM 5/1/2003]
[Modified by RUSS105, 7:50 PM 5/1/2003]
Old May 1, 2003 | 08:14 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Synthetic ATF (RUSS105)
:iagree: with your mechanic! Flush it all! There are numerous posts in the archives on this subject, try the SEARCH function. Will take around 13 quarts to flush and fill
:steering:
Old May 1, 2003 | 08:33 PM
GlockLT4's Avatar
GlockLT4
Definitely flush it out until it's a nice clear red. And use mobil 1 synthetic ATF ... GOOD STUFF!!!!!! :yesnod:
Old May 1, 2003 | 10:10 PM
CorvetteKid1983's Avatar
CorvetteKid1983
Default Re: Synthetic ATF (GlockLT4)
:iagree: Mobil 1 ATF is superb.
It is just like motor oil or brake fluid, or any kind of fluid. You can not mix non-synthetic with synthetic.
You will appreciate the synthetic ATF's attributes. Enjoy!
Old May 2, 2003 | 02:46 AM
skeet's Avatar
skeet
Default Re: Synthetic ATF (CorvetteKid1983)
If you can not mix synthetic with non-synthetic why do all the oil companies make a blend which is part synthetic and part non? Call 1-800-ASK-MOBIL and they will tell you you can mix them.
Old May 2, 2003 | 05:36 AM
JDANNER's Avatar
JDANNER
Mobil 1 ATF synthetic is the way to go.
Old May 2, 2003 | 07:02 AM
96LT1's Avatar
96LT1
Default Re: Synthetic ATF (JDANNER)
:iagree: Definitely good stuff.
BTW, synthetic fluids can be mixed with non-synthetic products, mixing them just reduces the effectiveness of the synthetic. As skeet said, most petroleum companies produce a synthetic/non-synthetic blend.
Old May 2, 2003 | 03:18 PM
RUSS105's Avatar
RUSS105
Default Re: Synthetic ATF (96LT1)
Thanks all. :auto:
To Synthetic ATF
