Disable EGR?
Old May 1, 2003 | 10:28 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Disable EGR?
Can I disable the EGR function in the PROM on my 91 Vette?
Di I need it for anything?
Old May 1, 2003 | 10:55 PM
drive it's Avatar
drive it
Default Re: Disable EGR? (VetNutJim)
Under ecm constants, increase to max values the minimum mat for egr enable. However if you're not changing the manifold to one without it, I'd just leave it enabled...it only functions at lower rpm/load and will help prevent detonation.
Old May 1, 2003 | 11:40 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Thanks Drive It.
I had planned to block it off on the manifold and disconnect it completely but if it helps reduce detonation then I agree with you it's best to leave it alone.
I'm just looking for all the "free" little things I can do.
I thought the dilution of the fuel mixture via the EGR would reduce power somewhat even if at lower power settings.
Old May 2, 2003 | 10:36 AM
devilfish's Avatar
devilfish
is it enough to block of the EGR port from the exhaust maifold to the intake base. Or do you have to do something else to?
Old May 3, 2003 | 10:09 AM
devilfish's Avatar
devilfish
Default Re: Disable EGR? (devilfish)
tt
Old May 6, 2003 | 11:45 PM
GlockLT4's Avatar
GlockLT4
My engine didn't come with one :D
Old May 7, 2003 | 01:34 AM
drive it's Avatar
drive it
You should disable it in the prom also-as above-then no codes will be set.
Old May 7, 2003 | 09:35 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Disable EGR? (drive it)
drive_it,
What parameter needs to be reset in the prom?
Just the EGR error code flag?
Old May 7, 2003 | 11:52 PM
drive it's Avatar
drive it
drive_it,
And also increase min mat for enable to max.
Old May 8, 2003 | 02:12 PM
Rynda's Avatar
Rynda
Frankly, I'd leave the EGR alone. It only functions at part throttle light cruise conditions. It allows you to run higher compression and more ignition timing with less NOx (the reason why it is there), since it cools down the combustion temps a little. My vaccum line to it was disconnected accidently and I got a O2 sensor voltage out of limits for too long of period.
But all that said, my education says that higher combustion temperatures result in more efficiency if you can avoid detonation.
On second thought, this sounds like a fun challenge. Defeat it and then get it tuned right and see how much better your gas mileage is.
To Disable EGR?
