Holley StealthRam
Old May 2, 2003 | 08:42 AM
Stingray1970's Avatar
Stingray1970
Default Holley StealthRam
Good test article in GM High-tech Performance July edition.
Old May 2, 2003 | 08:58 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: Holley StealthRam (Stingray1970)
I was quite impressed with the times that camaro ran, especially considering they used a somewhat mild flat tappet cam. The short block in my IROC is similar to their short block, so at least in theory, if I slapped a pair of those Trick Flow heads and a stealth ram onto my motor, along with a new cam, my car should see similar results. But then again, my car should run 13s with what it's got, and well... :rolleyes:
Old May 2, 2003 | 10:36 AM
loiq's Avatar
loiq
Default Re: Holley StealthRam (Jim85IROC)
I hope the rumor that Holley is making a plenum to allow the Stealth Ram to fit under the hood of a Corvette is true. That would make me :)
Old May 2, 2003 | 11:18 AM
Curveit's Avatar
Curveit
Do a search on Grumpyvette, and StealthRam. He's got It covered.
:chevy
Old May 2, 2003 | 11:39 AM
86VETTEMAN's Avatar
86VETTEMAN
Default Re: Holley StealthRam (loiq)
Quote:I hope the rumor that Holley is making a plenum to allow the Stealth Ram to fit under the hood of a Corvette is true. That would make me
If they are I hope they make a provision that will allow the EGR to be installed, for those of us who need/want emissions.
Old May 2, 2003 | 11:44 AM
LD85's Avatar
LD85
Default Re: Holley StealthRam (Curveit)
:chevy
:iagree: :iagree: :iagree:
Old May 2, 2003 | 12:16 PM
grumpyvette's Avatar
grumpyvette
Default Re: Holley StealthRam (ld85)
got questions?
send me an e-mail for details
prlangevin@hotmail.com
[Modified by grumpyvette, 5:17 PM 5/2/2003]
Old May 3, 2003 | 02:38 AM
SUPERNINJAB0Y's Avatar
SUPERNINJAB0Y
Default Re: Holley StealthRam (grumpyvette)
stealth ram might be a bit hard to pass cali's visual im guessing...unless they somehow slip by not noticing the awsome sight of that manifold! i'd like to know how to make it work for californians' trying to legally pass smog....any thoughts???? :confused:
To Holley StealthRam
