Drivers side hush panel
Old May 3, 2003 | 02:17 PM
JCAIRE2's Avatar
JCAIRE2
Default Drivers side hush panel
How do you remove it completely? I was only able to drop it down from the dash, but not pull it away from the firewall. What holds it to the firewall? I couldn't see any bolts, just what looked like two studs sticking out. Didn't want to force anything, so I just let it hang while I worked. Suggestions? :cheers:
Old May 3, 2003 | 03:59 PM
Siveck's Avatar
Siveck
Default Re: Drivers side hush panel (JCAIRE2)
On my '89, there is one stud on the firewall with a push clip on it.
Old May 3, 2003 | 04:44 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Drivers side hush panel (Siveck)
Thanks, couldn't get my fat head far enough in there to see the clip then. Most appreciated! :cheers:
To Drivers side hush panel
