Octane boost
Old May 4, 2003 | 08:18 PM
nopain1984's Avatar
nopain1984
Default Octane boost
Which is the best?No cat.They all claim points increased3-6? :chevy
Old May 4, 2003 | 08:34 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Octane boost (nopain1984)
I've heard that when they mean points that they mean " . 's " as in 93 would become 93.6
Don't know how much truth there is to that. Just curious what do you need it for?
Old May 4, 2003 | 08:51 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Octane boost (Nathan Plemons)
That is the truth nathan. Go to any reputable ocatne booster manufacturer website and it will have such a disclaimer. Each point is a 0.1. I'd look elsewnere if your having problems with detonation. You could always make your own octane boost. Do a google search and you'll find plenty of info :cheers:
Old May 4, 2003 | 09:17 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Octane boost (JCAIRE2)
You guys are correct 1pt =>.1 octane increase :rolleyes:
Your best bet is to mix toluene and reg gas for the desired octane...
Here is a formula that you can use
octane = (reg gas octane ie 94)(gal of gas ie 5)/(combined gals ie 7) + ( Toluene octane ie 104)(gal of toluene ie 2)/(combined gals ie 7)
octane=96.86 octane:D
You can also add some of the following ingredience to make your typical injectors cleaner/boost....
100 oz of toulene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes :cheers:
Old May 4, 2003 | 09:48 PM
nopain1984's Avatar
nopain1984
Default Re: Octane boost (ski_dwn_it)
No detonation! I used to run cam 2, and the car ran great!How about lead additive? no cat! :chevy
Old May 4, 2003 | 10:01 PM
Squareseven's Avatar
Squareseven
I recently tried 3 gallons of Xyene in my car with 93 octane.
The end result was kick butt! My car never drove so nice. hehe
The gas was around 97 octane. :cool:
Old May 4, 2003 | 10:10 PM
TurboVette's Avatar
TurboVette
I've been using toluene and/ or xylene for years. I found a 20% mix works very well at an affordable cost and when you pull the injectors, they always look new.
Old May 4, 2003 | 10:25 PM
LD85's Avatar
LD85
Default Re: Octane boost (TurboVette)
1 can usually = .2 or .3 octane
Old May 4, 2003 | 10:27 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
:confused:
What exactly are you trying to accomplish?!
Old May 4, 2003 | 10:57 PM
nopain1984's Avatar
nopain1984
Default Re: Octane boost (flyersfan1088)
Run better-run faster- Last longer! :chevy
Old May 4, 2003 | 11:05 PM
DougSilver's Avatar
DougSilver
Where can you easily obtain these minerals (paint supply store?). Do you need any special precautions/permits/etc. to handle this stuff? The octane here in California stinks (91 is not the typical "premium"). I am aware that some Union 76 stations sell 100 octane for about $5+ per gallon. I added one or two gallons of this stuff to a tankful of premium and it seemed to make a difference but I wonder if it would be cheaper to go the "home mixed" route with toulene or the other stuff you guys listed.
Old May 5, 2003 | 02:01 PM
vetteguy216's Avatar
vetteguy216
Default Re: Octane boost (DougSilver)
Yes I was wondering the same thing as DougSilver. Where can we get it and how much $$$. :confused:
Old May 5, 2003 | 06:34 PM
GlockLT4's Avatar
GlockLT4
Default Re: Octane boost (vetteguy216)
I tried Toulene from Ace Hardware .. expensive stuff! :eek: :eek:
Old May 5, 2003 | 06:51 PM
TurboVette's Avatar
TurboVette
I haven't bought any in two years but found it at a chemical supply house in the yellow pages. Phone around and buy a 55 gal drum and split it with your friends. It was quite inexpensive.
To Octane boost
