Single mass flywheel
Old May 5, 2003 | 04:04 AM
corvette90's Avatar
corvette90
Default Single mass flywheel
hi all..
i want to do the single mass conversion on a 90L98...
does anybody know, where i can buy a balanced single mass FW for an 90L98??
thanks :cheers:
Old May 5, 2003 | 05:51 AM
corvette90's Avatar
corvette90
Default Re: Single mass flywheel (corvette90)
....and..can a "broken or weak" dual mass FW cause Vibration under load, like goin uphills, and make some noises??
thanks
pablocruise's Avatar
pablocruise
Hello.
I never found any company that had a single mass flywheel already balanced to our L98's. How would they know how to balance it? Here is what I did:
I took my DM to a machine shop with balancing capabilities and had them match the same amount of weight in the same location as the DM onto a camaro FW. The motor felt balanced after that, but recently that motor broke. So be careful.
[Modified by 89 Paul in Cal, 3:20 AM 5/5/2003]
Old May 5, 2003 | 06:08 AM
corvette90's Avatar
corvette90
Default Re: Single mass flywheel (89 Paul in Cal)
do you mean, that your motor broke ???
do you think, its related to the single mass, or just a bad timing???
Old May 5, 2003 | 06:19 AM
pablocruise
Well a piston broke and my main bearings looked really bad. I am pretty sure it was not my single mass but I just want to make sure you know what happen to me. Lots of forum members using single mass. I don't know how they balanced their SM FW to their L98. I hope some of those guys post here so I can know too.
Old May 5, 2003 | 06:52 AM
corvette90's Avatar
corvette90
uh..that sounds bad :eek: but...i dont think too, that this is related to the FW. because i think wrong balanced FW destroyes the crank...
ok, hopefully somebody will chime in..
thanks
Old May 5, 2003 | 07:38 AM
ludachriss2's Avatar
ludachriss2
Spec clutches sells what they claim is a balanced sigle mass aluminumm flywheel. I put one in my 91 coupe a couple of months ago. I have NO complaints whatsoever. Price was decent, customer service was great. Drop me an e-mail at ludachriss2@yahoo.com if you can't locate them on the web. I have the paperwork somewhere. Good luck :seeya
Old May 5, 2003 | 07:47 AM
Atok's Avatar
Atok
Default Re: Single mass flywheel (ludachriss2)
Broken piston, destroyed main bearings....Sounds like a bad case of prolonged detonation to me.
Old May 5, 2003 | 08:08 AM
corvette90's Avatar
corvette90
Default Re: Single mass flywheel (Atok)
hi..ive checked the net so far..Doug Rippie sells a single mass flywheel assembly..for LT1and LT4
what i know is the bottom of the LT1 tha same as L98
do you agree???
Aluminum single mass...don´t know, what i´ve heard the cars get harder ti launch..
thanks
Old May 5, 2003 | 11:16 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Doug Rippie sells single masses for L98 too but as far as I know they are f-body flywheels machined down a touch. If I did a single mass conversion again I would go for an aluminium fw next time with a replaceable friction surface.
Whether you like the conversion or not depends on what you like in a car. You have to slip the clutch a bit more when taking off ordinarily but it's no biggie. As far as whether a single mass helps or hurts acceleration, I won't get into that debate. :)
If you do a search in the C4 tech archives you should find a bunch of stuff if you search under "single mass".
HTH
Old May 5, 2003 | 11:27 AM
jburnett's Avatar
jburnett
Default Re: Single mass flywheel (Red 90 L98 Coupe)
If you've got a motor that doesn't turn real high or make in excess of 450 hp or so you can take the cheap route out... Go to GM and buy a flywheel for a 86-88 Corvette; it's a 153 tooth L98 piece, single mass for the 4+3 DNE trannys. Then go to RAM clutches and tell them you need a single mass clutch disk for your year Vette (the main diff is the disk's hub if I recall correctly). You can then either use your factory pressure plate (if it's in good shape) or buy a new one. Oh, you will also need a longer clutch fork pivot stud...That's it...Pretty simple.
-Jeb
To Single mass flywheel
