install and codes
Old May 5, 2003 | 08:35 PM
old salt's Avatar
old salt
Default install and codes
i just finished a 1994 406 with a 10 psi paxton. i cant get rid of the code 33. it shows the map signal high. any suggestions. it seems not to rev up too good. breaks up spits and sputters . fuel pressure is about 60psi.
Old May 6, 2003 | 01:41 AM
drive it's Avatar
drive it
Default Re: install and codes (old salt)
You need to tune it....there is a table on the prom program to change the parameters on code 33. Also are you using an fmu? If not and no tuning; just turning up the fp isn't going to do it....
