Fuel Line Questions
Old May 5, 2003 | 10:15 PM
joalyons's Avatar
joalyons
Default Fuel Line Questions
What is this thing in the return line and can I remove it when I use Stainless Steel braded line?
http://imageevent.com/joalyons/vette...=0&w=1&s=0&z=2
[Modified by joalyons, 9:16 PM 5/5/2003]
Old May 5, 2003 | 10:55 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Fuel Line Questions (joalyons)
Vibration/pulsation damper (?)
Old May 6, 2003 | 11:25 PM
don hall's Avatar
don hall
I'm betting that it is a pressure relief valve.
Old May 6, 2003 | 11:26 PM
Darkness's Avatar
Darkness
Default Re: Fuel Line Questions (Oldman)
FPR ???
Old May 7, 2003 | 12:17 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Fuel Line Questions (Lone Ranger)
Came up in conversation a week or two ago...
Vibration/pulsation damper is correct. This was removed in the '93 and up models (maybe starting in '94).
Old May 7, 2003 | 09:07 PM
joalyons's Avatar
joalyons
Thanks, I am going to use Stainless braided line in place of the stock lines and remove it will I experience any problems?
Old May 7, 2003 | 09:40 PM
ittlfly's Avatar
ittlfly
Its called an accumulator. It acts to dampen fuel line vibrations. If you don't install it, and get unusual noise vibrations (rattling) from the right side, you will know why.
[Modified by ittlfly, 6:40 PM 5/7/2003]
Old May 8, 2003 | 01:38 PM
R23HTC's Avatar
R23HTC
Default Re: Fuel Line Questions (Vette92)
Was there a second one? According to my service manual ('94), the part you plug the fuel pump into is the Fuel Pulse Dampener? :confused:
Old May 8, 2003 | 02:43 PM
ittlfly's Avatar
ittlfly
Default Re: Fuel Line Questions (R94 LT 1)
Was there a second one? According to my service manual ('94), the part you plug the fuel pump into is the Fuel Pulse Dampener? :confused: [/QUOTE]
Yep. I guess there were problems. Also, the dampener in the fuel pump (if i'm not mistaken) also acts like a check valve to prevent back flow of fuel through the feed line. There IS a check valve at the pump and I thought it was at the fuel pulse dampener.
Old May 8, 2003 | 07:29 PM
Lone Ranger
:hurray: :hurray: Do I win a prize for the 1st right answer :jester
Old May 8, 2003 | 07:36 PM
R23HTC's Avatar
R23HTC
Here ya go :cheers: :cheers: :cheers: :cheers: :cheers: :jester
Old May 8, 2003 | 09:36 PM
ittlfly's Avatar
ittlfly
Don't want to burst your bubble...but the 92 Helms manual still calls it an
"accumulator". :p:
Old May 8, 2003 | 10:25 PM
joalyons's Avatar
joalyons
Everyone wins the prize for the help. :party: I think I will be ok without it since the Stainless lines should absorbe the vibrations.
To Fuel Line Questions
