Vacuum under TB?
Old May 6, 2003 | 10:30 AM
30th b-day's Avatar
30th b-day
Default Vacuum under TB?
Can anyone tell me where the vacuum line uner the TB is supposed to be hooked up to? I have converted to a Holley stealthram, And dont remember if this line needs a source, or if it is a source that needs to be hooked to something? Thanks in advance
Old May 6, 2003 | 01:17 PM
vetracer's Avatar
vetracer
Default Re: Vacuum under TB? (30th b-day)
The vaccum line under the TB on my '86 goes to a solenoid on the intake manifold just behind the thermostat housing. There is another vacuum line coming out of this solenoid which controls opening and closing of the EGR valve. So I guess it the connection under the TB would have to be a vacuum source. :seeya
[Modified by vetracer, 6:18 PM 5/6/2003]
Old May 6, 2003 | 01:39 PM
lead_foot's Avatar
lead_foot
Since the Holly does not have an EGR connection, what did you do and will it still pass emisions? :)
Old May 6, 2003 | 02:16 PM
JayH's Avatar
JayH
On my '95 that port supplied vacuum, through two one way valves, to the optispark.
Jay
Old May 6, 2003 | 02:50 PM
30th b-day's Avatar
30th b-day
Default Re: Vacuum under TB? (lead_foot)
Don't know about passing emissions, or care for that matter. We dont have them up here. I just hooked a vacuum hose up to that line and ran it to a manifold vacuum.
Old May 6, 2003 | 07:12 PM
lead_foot's Avatar
lead_foot
So does it run OK w/o the EGR?
Old May 6, 2003 | 09:13 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Old May 6, 2003 | 09:25 PM
30th b-day's Avatar
30th b-day
So far it is running ok, but I have only just finished doing the cam break-in. Haven't had it on the street yet, but I am not worried about it. The guy that did my chip said that he could take out the signal or whatever, if I didn't want it there. So far no codes going off.
Old May 8, 2003 | 09:20 AM
rodj's Avatar
rodj
It is a vacuum source for the EGR (through the electically operated solenoid) and to the vacuum operated valves on the fuel vapour system in the driverside front wheelwell. I think it may be ported vacumn as the constant vacuum ports(for the FPR ) are located at the rear of the manifold. '87
To Vacuum under TB?
