building my exhaust system..
Old May 6, 2003 | 01:25 PM
devilfish's Avatar
devilfish
Default building my exhaust system..
hello
I got my hedman headers in place.
Im going to use my stock y-pipe as for now.
I have cut it behind the precats, just before the tube starts to turn uppwards.
I have put it in place, and the length of my newly cut y-pipe is correct BUT ( there is always a but ), the angel is off.
Now, i cant use standard pipe bends that exhaust shops sells, becuse its to tight.
The only option I have is to custom make bends using a welder. Another option I thougt of I using some kind of "flex" pipe? Is that ok? And where can I get those?
Old May 6, 2003 | 02:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: building my exhaust system.. (devilfish)
All you realy need is the short "Y" piece in front of the cat, right?
Then you can cur & weld sections of 3" tubing to contour.
Old May 6, 2003 | 02:07 PM
devilfish's Avatar
devilfish
Default Re: building my exhaust system.. (65Z01)
true.
is there som good way you can mesaure on what you need? Its hard to se. Or is it just to buy alot of bends and straits pipe to make a rial and error kind of building?
and do i really need 3" ?
Old May 7, 2003 | 05:34 AM
Cratzy's Avatar
Cratzy
Ofcourse you will need 3"!! Atleast :D
I will send you some pics of how I did it.
:cheers:
To building my exhaust system..
