Supercharger on ebay for cheap...
Old May 8, 2003 | 01:40 PM
85superram's Avatar
85superram
Default Supercharger on ebay for cheap...
its for the camaro/firebird 350 TPI.....it is the paxton setup.......will they fit our cars??????? I know the smog pump is where the bracket should be.....can it be made to work easily??????
Old May 8, 2003 | 02:38 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Supercharger on ebay for cheap... (85superram)
No it won't work. The location of the alternator on camaros/firebirds are different. You'll need a corvette specific bracket that accommodates the alternator for a reverse setup. If the setup is cheap enough, get it and then go to Carrolls website and buy a bracket for $350. :cheers:
Old May 8, 2003 | 02:49 PM
85superram's Avatar
85superram
Default Re: Supercharger on ebay for cheap... (NUckINg FuTS)
800 bucks is that cheap enough?.....is that the only difference???
Old May 8, 2003 | 03:09 PM
MrNuke's Avatar
MrNuke
The thing that would make me think about 100 times about this is the fact it is a PAXTON supercharger..... :U
Old May 8, 2003 | 03:18 PM
85superram's Avatar
85superram
Default Re: Supercharger on ebay for cheap... (MrNuke)
Sorry for my ignorance.....are they poopiety chargers????
Old May 8, 2003 | 04:05 PM
NUckINg FuTS
There are better and more expensive chargers out there that'll give more boost (Vortech, ATI). If you engine is close to stock then there is no need for more then what a paxton can dish out (6-8 psi, modded 10-12 psi). For the money you can get a paxton setup for, I would give it a try. I would install heavier duty bearings in it if I was you. Also, a good ideas is to get an oil cooler for the head unit to prolong it's life.
Old May 8, 2003 | 06:48 PM
lead foot 85 vet's Avatar
lead foot 85 vet
if it's the novi head unit it won't fit the l98...........check the archive under paxton for info :cool:
To Supercharger on ebay for cheap...
