Fans?
Old May 8, 2003 | 08:35 PM
CENTURION's Avatar
CENTURION
Default Fans?
My front fan comes on at around 230 deg, when does the larger one on the engine bay side supposed to come on? or are they both supposed to come on at once ,and one is not working?
Old May 8, 2003 | 08:45 PM
don hall's Avatar
don hall
Default Re: Fans? (CENTURION)
You should have a primary and secondary fans. Sounds like one is not working.
Old May 8, 2003 | 09:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The aux fan switch in the block between #1 & #3 plugs has exclusive control over the front fan through the aux fan relay on the left side of the radiator shroud; the ECM has exclusive control over the rear (main) fan and only over that fan through the main fan relay on the rear of the left inner fender well.
It sounds as though you have a problem with the main fan control. Try this: 1. Open the A/C pressure switch connector near the blower motor housing, start the engine and the main fan should come on immediately. If so, replace the coolant temp sensor in the top of the block under the TB.
2. If not ground the grn/yel wire at the main fan relay and the main fan should come on. If so wring out the wiring from the ECM to that relay.
3. If not, open the connector at the fan, ground one fan motor terminal and tap a jumper from the other terminal against the battery + lead and the fan should run. If so, replace the main fan relay.
4. If not replace the main fan motor.
To Fans?
