polishing Q:
Old May 8, 2003 | 09:25 PM
Ramanstud's Avatar
Ramanstud
Default polishing Q:
I just sanded with 600 grit paper and finished with a drill-mounted buffing wheel & final stage grit... how do I get the residual buffing compound off?
I tried rubbing it with a little carb cleaner and it doesn't really want to come off the aluminum (plenum).
Any ideas?
Old May 8, 2003 | 09:35 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: polishing Q: (Ramanstud)
I used white rubbing compound on mine after I sanded it.
Then I used wheel polish. It shines like a mirror. Only took a couple of hours to do the whole thing.
Old May 8, 2003 | 09:38 PM
Ramanstud's Avatar
Ramanstud
Default Re: polishing Q: (VetNutJim)
ok, but the polish that I did use left a little bit of buildup/residue on some spots. I take the wheel back over it and nothing much happens. It's shiny enough for me- I just want to get the leftovers off.
what chemical? :D
Old May 8, 2003 | 10:19 PM
2dogs's Avatar
2dogs
Buff it with a polishing compund with less oils in it. The whiter compounds usually work for me.
I will wash my Al wheels with car washing soap then you can dry and buff a clean towel.
This post has somes tips and tricks: http://coloradok5.com/forums/showfla...t=1&PHPSESSID=
Old May 8, 2003 | 10:23 PM
joalyons's Avatar
joalyons
I use a hand polish (like Mothers) with a polishing cloth. It all seems to come off.
To polishing Q:
