Average MPG never changes??
Old May 8, 2003 | 10:03 PM
JB666's Avatar
JB666
Default Average MPG never changes??
Why?? For as long as I've had my car, and driven it the whopping 200 miles I've put on, the AVERAGE MPG has never changed... Is this something I need to reset occasionally?? I'd figure, it should be going up & down depending on driving habits, but it doesn't ever move.. Help!
Old May 8, 2003 | 10:09 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Average MPG never changes?? (Jbaker)
The average MPG will continue to calculate the average for as long as you want before you reset it.
So if you've never reset it this doesn't suprise me at all. For instance if you drive 300 miles getting 15 mpg, that one mile at 1 mpg doesn't do much to affect the overall average.
I reset mine every time I get gas.
Old May 8, 2003 | 10:12 PM
JB666's Avatar
JB666
Default Re: Average MPG never changes?? (Nathan Plemons)
No, I've never reset mine. To be honest with you, I should have done it when I first bought the car!! Is it as easy as holding in that RESET button when the MPG is displayed?? Thanks.
Old May 8, 2003 | 10:13 PM
GlockLT4's Avatar
GlockLT4
You have a really steady foot :jester
Old May 8, 2003 | 10:36 PM
Steel Blue 91's Avatar
Steel Blue 91
You are correct. It really is that easy. Just push the fuel reset button. I do it after a fill up.
Old May 8, 2003 | 11:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Push the reset button; if the avg MPG reading goes to zero and then tracks the instentaneous reading for a while all is well.
Old May 9, 2003 | 08:36 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: Average MPG never changes?? (65Z01)
I find myself constantly fixated on that silly display, so I turned mine off. :lol:
Old May 9, 2003 | 08:44 AM
BIG JIM 54's Avatar
BIG JIM 54
The only reason I stay with early C4's is the extremely accurate, readable and informational digital dash. An analog gauge that has a needle between two ambiguous and far apart numbers does nothing for me. Don't turn anything off. More information makes you a better C4 owner.
Yeah, just reset it. :iagree:
[Modified by BIG JIM 54, 1:48 PM 5/9/2003]
Old May 9, 2003 | 01:51 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:withstupid: along w/ my trip mileage :D
Old May 9, 2003 | 02:06 PM
BookSmart's Avatar
BookSmart
Default Re: Average MPG never changes?? (_freakmonkeydogboy_)
Yup I reset mine every time I get gas. I love the info. I am a number freak. Got 400 miles out of my last tank of gas and had 30 miles till empty. Car starts to run out of fuel when you get on it that low. 27-28 MGP on the freeway 16-17 in the city 25 on average for my trip.
Insta fuel MPG and average up on the dash is the best. Makes me feel like I drive a really high end car because most cars don't have that stuff. I love my car. :yesnod:
Old May 9, 2003 | 02:41 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Currently Corvette-less
Default Re: Average MPG never changes?? (BookSmart)
I check mine ~ but the home station is tuned to : Coolant Temperature
That is the most critical reading for me.
~ Purp
Old May 9, 2003 | 02:50 PM
Steel Blue 91
Default Re: Average MPG never changes?? (PurpleC4)
~ Purp
Wish I had that option. The critical readouts on the 91 are all analog. Makes it sort of a guessing game.
Old May 10, 2003 | 08:17 AM
Nathan Plemons
Default Re: Average MPG never changes?? (BIG JIM 54)
Some people would argue that it's easier to glance at an analog gauge and know everything is normal. That's why I love my 92 so much, it has BOTH the analog gauges and digital. I can glance and see if everything is alright yet if I need to pay closer attention to something I can choose to do so.
The tach would be a good example, who has never confused a 3 for an 8 on an digital LED display, 5300 could look at a lot like 5800 or vice versa. An analog gauge you can see out of the corner of your eye, a digital gauge that displays numbers you actually have to focus on and read.
To each their own but I prefer analog gauges. For instance my fuel pressure gauge, I can see it moving out of the corner of my eye and see what direction it's moving. If it was digital I would be able to see it was changing but would have to focus on it to see if it was going up or down. :cheers:
Old May 10, 2003 | 03:26 PM
scorp508's Avatar
scorp508
Like others have said, if that thing has been reading an average for 40k miles I'll be surprised if you EVER see it change. :D I reset mine often to see how I do on trips.
Old May 10, 2003 | 03:41 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Average MPG never changes?? (scorp508)
Also if someone had a scanner connected to the car at some time and decided to perminately fix a 10k resistor between the A&B terminals on the diagnostic port, your ave mileage will remain the same.
Check for a short between those two terminals. :cheers:
To Average MPG never changes??
