Dead 88?
Old May 9, 2003 | 11:15 PM
CENTURION's Avatar
CENTURION
Default Dead 88?
Car ran great for about a month, shut it off at the store a few blocks from home, get back in the car and the starter does nothing. Battery is OK, any real simple things to look at first? terminals are tight, lights, windows etc. work good. I'm thinking a starter or computer. Any thoughts?
Thanks.
Old May 9, 2003 | 11:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Dead 88? (CENTURION)
Try wiggling the shifter in Park.
Old May 9, 2003 | 11:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Dead 88? (65Z01)
:iagree:
Also, VATS?
Old May 10, 2003 | 06:55 AM
CENTURION's Avatar
CENTURION
I'm starting to think battery, had to have brought home on a flat bed last night and what do you know? it starts this morning. Perhaps the volt gage is not reading correctly? what are your cars indicating consistently on the gages?
Thanks.
Old May 10, 2003 | 08:04 AM
Mr Mojo's Avatar
Mr Mojo
My volt meter reads anywhere from 12.7-14.3 while running.
Sounds like a VATS problem, I've seen it happen on others. The car won't start, there is some kind of reset procedure where you have to wait and then thecar will start.
Hopefully someone can fill inmore on this procedure, butthat's what it sounds like to me.
On other cars I've owned, the neutral safety switch was bad and jiggling the shifter like Jim mentioned will be a temporary fix. Enough to get you home anyway.
Old May 10, 2003 | 09:14 AM
CENTURION's Avatar
CENTURION
Default Re: Dead 88? (Mr Mojo)
What is VATS?
Old May 10, 2003 | 09:21 AM
CENTURION's Avatar
CENTURION
Oops! found my own answer, Vehicle Anti Theft System. If you wait over 4 mins. will it start again? or is it better to by-pass this thing? or get new contacts ?
Thanks.
Old May 10, 2003 | 09:39 AM
65Z01's Avatar
65Z01
To eliminate the VATS from the picture you can install one of the VATS eliminator switches from MAD or Eckler's.
Old May 10, 2003 | 10:03 AM
Slalom4me's Avatar
Slalom4me
Doesn't cleaning the key help?
Haven't had the problem myself, but I believe
I read that using something (isopropyl alcohol?)
helps restore conductivity through the contacts
in the ign switch and the resistor pellet.
I suppose a pencil eraser might do the job, too.
You DO have spare keys you can try, also, right?
In "Top 50 Questions" Vol II Gordon Killebrew writes
about 'No Start - VATS' and describes conditions
for the different generations of VATS in C4's. Buy
his publications - in the meantime check out the
key, the lock cylinder or consider a VATS bypass
resistor.
Contact info for Gordon Killebrew
"For Your Car Inc"
http://www.gordonkillebrew.com
ph: 1-800-F-Y-VETTE
To Dead 88?
