Ignition Module
Old May 13, 2003 | 05:01 AM
premiervette's Avatar
premiervette
Default Ignition Module
Ive been looking to order a module for my 87 but i dont know which one to get the DUI, Accel, or Jegs. let me know what you guys think is the best one to get, thanks. :cheers:
Old May 13, 2003 | 12:12 PM
jfb's Avatar
jfb
Default Re: Ignition Module (premiervette)
What is wrong with the GM part? If you think an aftermarket ignition module is going to provide a hotter spark, then you are a victim of advertising or misinformation. To the spark coil, the ignition module is a power transistor that switches 12 volts to the primary for a short duration to generate a spark.
The aftermarket ignition modules also use a power transistor to switch 12 volts to the primary of the spark coil for a short duration to generate a spark. There is no difference between a 12 volt pulse from a GM or an aftermarket ignition module.
Old May 13, 2003 | 02:53 PM
vader86's Avatar
vader86
The stock one is perfect until you significantly modify the intake.
You have to get to high rpms before the HEI system really starts falling off.
To Ignition Module
