WaterWetter, an concerns???
Mike
And use distilled water with the glycol, definitely do not use tap water.
Flush and replace the coolant evey two years. Do not use Dex-Cool unless
the car came with it ('96 only for C4s, I believe).
[A side note - antifreeze smells and tastes sweet. Small animals and
children are attracted to it. If antifreeze is consumed, severe illness
will occur - possibly resulting in a painful death. Do not leave the
old coolant out in uncovered containers.]
As for the original question:, nope, no concerns about Water Wetter.
[Modified by Slalom4me, 3:49 AM 5/14/2003]
What brand of a/f did you have trouble with ?
Unless you use just water I would not chance using it.
What ever came in the car when I bought it.
because others have used W/W with water/glycol mixes without
those kinds of problems. Perhaps there was some additive in
there?
Water in a street engine just isn't a good idea, especially tap water.
Racers drain theirs frequently, street-folk put it in there and forget
about it, leaving chemistry between the salts & minerals in the
coolant to work its magic on the iron, aluminum and other metals
in the engine.
[Modified by Slalom4me, 8:38 AM 5/16/2003]
Could be that the thick brown stuff was a result of too much anti-freeze not enough water so the water wetter emulsified with the anti-freeze. Brown stuff in coolant sounds like rust or someone used the orange stuff without thoroughly flushing the green stuff.
Thanks for the info. :thumbs:
I use it in my '84 vette.....without problems.....(REMEMBER DISTILLED WATER)....
ok....
tony
:flag :flag :thumbs: :flag :flag
[Modified by oldace84, 10:44 PM 5/16/2003]
Happened to a friends car when he topped off, said he thought the orange stuff was probably better, cause it cost a bit more (FOOL!) they coagulate into a thick goo when mixed. Always better to ask, rather than assume!
If you care to run pure water for the cooling benefit, you must use an additive such as WW to prevent corrosion, reduce cavitation, include some wetting agents for improved heat trasnsfer and provide some lubrication. That is the purpose of Water Wetter and regular coolant mixes.
The purpose of WW is to provide most coolant properties w/o anti-freeze for improved cooling. It has little value added to a coolant mix, IMO.
Pete
You live in AZ you should do what I did. Pull the thermo. Run 1/2 to 3/4 gal antifreeze and the rest water. I run about 149F on the freeway at night in CA. 170F around town. The only time the fans come on is when I sit in a fast food drive-thru.
Don't just run straight water. It has no lubrication for the water pump. You have a really nice and rare car. I wouldn't screw with it too much.
BIG JIM
But a year ago I discovered that my car was burning coolant due to a bad headgasket that was leaking at cylinder #7. I've replaced the gasket and haven't put WaterWetter back in my car. It's definitely runnung hotter than it did with it, but I have to ask the question - did the WaterWetter contribute to my headgasket going bad seeing as so many people have had bad experiences with it? I don't know, but I don't think I will use it again.
Cars & Parts Corvette magazine has a really good tech article in it this month dealing with tried and proven C4 cooling tips. I'll go through it tonight when I get home and let you know what they say.
If you really want to drop your temperatures, replace your thermostat with a 160deg unit. I replaced mine when I changed my head gaskets and it's great! In fact, I have to take my thermostat housing off to replace the gasket (it's leaking :rolleyes: ) and I think I will do what the guys at TPiS suggest and drill a couple of holes in the t-stat's surrounding plate. That should REALLY help keep the car nice and :cool: .
[Modified by TheCorvetteKid, 8:10 PM 5/27/2003]
