WaterWetter, an concerns???
Old May 27, 2003 | 03:21 PM
vetracer's Avatar
vetracer
Default Re: WaterWetter, an concerns??? (TheCorvetteKid)
What you are saying about the WW deteriorating the head gasket may have some merit, somehting I hadn't thought about. I disagree about the thermostat, once your cooling system reaches its limit (thermostat all the way open, temperature climbing) the 160 degree thermostat won't be any more open than if you had a 180. A lower thermostat will only lower your car's operating temperature if the cooling sytem isn't working at max capacity (such as in cooler weather). There are only two things that made my C4 run cooler and that is increasing the airflow through the radiator and increasing the size of the radiator itself.
