X-pipe help
Old May 13, 2003 | 07:39 PM
MongooseLT4's Avatar
MongooseLT4
Default X-pipe help
Where should I get my X-Pipe from for my TPIS Longtubes?
Can I get it coated and whats the part number.....Pictures also :thumbs:
Old May 13, 2003 | 07:46 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: X-pipe help (MongooseLT4)
Check Dr. Gas ( I think it is drgas.com). I used their cross over (X-pipe) several years ago on my old Nova. Going from open headers to a 3" Dr. Gas cross over and 3' Flowmasters picked my car up almost a full .1 and 2 mph in the quarter mile.
When I get around to it, I am going to put one on my LT-4.
Old May 13, 2003 | 08:10 PM
luvmy92's Avatar
luvmy92
What exhaust do you have? I too have TPIS headers and use the 3" Dr Gas X-Pipe. Mine is used in place of the resonator on my Tri-Flow exhaust. I highly recommend it...
Mike
Old May 13, 2003 | 08:17 PM
MongooseLT4
Default Re: X-pipe help (luvmy92)
I'm going to use the stock Catback for awhile
Did you get them coated....do I just call up Dr. Gas and tell them my setup and they will beable to make one for me?
Old May 13, 2003 | 08:30 PM
luvmy92's Avatar
luvmy92
Since the x-pipe is not seen, I did not have mine coated. I have had it for 3 years now and it is still functioning fine. They will make you a custom tandem pipe (w/mandrel bends) with whatever dimensions you give them. What they will want to know is the length, the diameter (your stocker is 2.75") and the distance from the 2 inputs pipes (inside to inside) and 2 output pipes (inside to inside).
If I were you, I would wait til you get your exhaust. As it stands right now, you will have to cut out your resonator (unless you plan on putting it somewhere else) and will want to weld the x-pipe in place. If you buy a catback, you can just have the x-pipe built to replace the resonator that comes with the exhaust. This way, you can use the clamps to install it.
Mike
Old May 13, 2003 | 08:33 PM
MongooseLT4
What do guys do that run Long Tubes and stock catback?
Old May 13, 2003 | 08:39 PM
luvmy92's Avatar
luvmy92
I would think they cut out their resonator and put it there. If you are getting long tubes, I'm sure you know you will be removing your cats and will be cutting your exhaust to mate up with the headers. It's possible to put some bullit cats in there but it's a real tight fit...
Mike
Old May 13, 2003 | 08:43 PM
luvmy92's Avatar
luvmy92
Here's a shot of mine before we did any welding. That's the Dr Gas X-Pipe in the middle but it's tough to see from this angle. Also notice the 8 inch extensions... that is where the bullet cats would go.
Mike
Old May 13, 2003 | 08:45 PM
MongooseLT4
So I would just put on the LT's and cut off everything in front of my resinator and then call up Dr. Gas and Give them my dimentions for a new X-pipe...correct?
BTW Thanks for all your help your giving me :thumbs:
Old May 13, 2003 | 08:52 PM
luvmy92's Avatar
luvmy92
You wouldn't cut off all the exhaust before the resonator. Notice my X-Pipe is in place of the resonator, and there's still plenty of exhaust coming out of the headers and 8" extensions and leading into the x-pipe.
You will need some form of extension (pipe or bullet cat) on the drivers side because the exhaust is shorter on that side and the header collector won't reach it. I cut both of mine to the same place because I was originally going to insert some bullet cats...
Mike
[Modified by luvmy92, 7:53 PM 5/13/2003]
Old May 13, 2003 | 08:56 PM
MongooseLT4
I just thought of a great idea....my buddy can make Y-pipes and is a really good welder, I'm going to see if we can't just pick up a bunch of stainless steel pipe and a X-Pipe junction and see if he will do one for me...... I would of possiable like the from the headers to the end of the X-pipe to all be one peice.
[Modified by MongooseLT4, 9:09 PM 5/13/2003]
Old May 13, 2003 | 08:59 PM
luvmy92's Avatar
luvmy92
What do you need a y-pipe for? Your car has a true dual exhaust on it...
Mike
Old May 13, 2003 | 09:02 PM
MongooseLT4
I've seen him make Ypipes before....I'm going to see if he will do an X for me :cheers:
Old May 13, 2003 | 09:05 PM
luvmy92's Avatar
luvmy92
I'm with you now. That makes sense and should work. Good luck with it...
Mike
Old May 13, 2003 | 09:10 PM
MongooseLT4
Thank you and thanks again....I had no idea where the X-pipe was suppose to go or anything, good job on clearing that up for me
-Nathan
:cheers:
To X-pipe help
