Sealed beam vs composite lights
Old May 14, 2003 | 08:49 AM
Strick's Avatar
Strick
Default Sealed beam vs composite lights
My son and I stopped by a "Wheel Shop" that had many aftermarket items one of which was a set of plastic projector style head lights. They were much lighter than the sealed glass beam lights and looked very :cool: My thinking was that they might be easier on the bushings, gears and motor, while giving a neater light. I was also concerned about the plastic becoming worn quickly, but the "salesman" said there is a plastic polish that keeps them clear. Anybody ever use these? $55. a set. :cheers:
Old May 14, 2003 | 10:02 AM
c4cruiser's Avatar
c4cruiser
Default Re: Sealed beam vs composite lights (Strick)
There are two very popular replacement headlamps setups on the Forum. One is the Sylvania SilverStar replacement headlamps. Much better light and a brighter light than stock. The other is Hella lamp housings and APC Xenon bulbs. The Hella's are glass but they really aren't that much heavier than stock lamps. I've had them in my 92 for a couple years now and no problems at all with the motors or gears.
The SilverStar lamps are fairly inexpensive and can be found at most auto parts stores. The Hella lamps and APC bulbs are available from Summit Racing. The Hella's come with a halogen H4 bulb which is better than stock, but the APC Xenon bulb is a bright white and more powerful.
Old May 14, 2003 | 10:39 AM
Strick's Avatar
Strick
Default Re: Sealed beam vs composite lights (c4cruiser)
Thanks C4Cruiser. Does your light have a blue tint to it?
Old May 14, 2003 | 11:50 AM
c4cruiser's Avatar
c4cruiser
The APC bulbs have a blue coating but the light output is a bright white but not like HID lighting. I have SilverStar bulbs on my 99 Silverado and the light output is very similar to the APC bulbs but less wattage. In this pic, the inside (high beams) are APC bulbs and the outside (low beams) are Silverstars:
Old May 14, 2003 | 12:55 PM
BlackBeast2's Avatar
BlackBeast2
Could you supply us with a picture or link?
Old May 14, 2003 | 01:59 PM
Strick's Avatar
Strick
Default Re: Sealed beam vs composite lights (BlackBeast2)
Let me work on it. Maybe they will have something at the store.
To Sealed beam vs composite lights
