Code 41??
Old May 14, 2003 | 11:25 PM
85z51vette's Avatar
85z51vette
Default Code 41??
I've got a code 41 on my '94. I've found this to be "Ignition Control Circuit Open". What exactly is this and what should I do? TIA!!
:cheers:
Old May 14, 2003 | 11:41 PM
Never9Fast3Enough's Avatar
Never9Fast3Enough
Default Re: Code 41?? (85z51vette)
For my 93, DTC-41 is "Cylinder select error". Manual suggests checking PROM to ensure the locking tabs are secure. I wouldn't know if they are different or not between 93 and 94, but I have a DTC-42 code now which is an Ignition Control Timing Circuit problem. Read a couple of posts down for the advice I have received.
Old May 15, 2003 | 12:27 AM
1 Badboy's Avatar
1 Badboy
Default Re: Code 41?? (Never9Fast3Enough)
I fought a code 41 last summer for way too long in my 93. GM manual gives a good troubleshooting flow. I followed it exactly and determined it was a bad IC module.
Bought a new one from NAPA, put it in and ... code 41 still there!
Did more troubleshooting- checked grounds, continuity from ECM to IC module,- finally replaced ECM and still no luck.
Bought a new multimeter and started from the top again and once again the result was a faulty IC module! But I had a new module with zero miles on it. WTF!
I decided to buy a new AC/Delco IC module from PartsAmerica.com. The brown truck delivered it , in it went and ... VRROOMM! Started right up and has run perfect everyday since.
I guess I'll stick with parts from the General.
The AC/Delco web site says your IC module for a 94 is part number D1986A.
Goes for $74.99 at PartsAmerica but shop around.
Also, code 41 and 42 seeem to have the same fix per the GM manual.
<A HREF="http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=S EARCHRESULTS&MfrCode=ACD&MfrPartNumber=D 1986A" TARGET="_blank">http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=S EARCHRESULTS&MfrCode=ACD&MfrPartNumber=D 1986A</a>
Old May 15, 2003 | 11:43 PM
Never9Fast3Enough
Default Re: Code 41?? (1 Badboy)
Where did you get your multi-meter? I think I am going to follow your lead and attempt to track down my problem using the manual. I also like the idea that I might be able to get on the road again without putting in a new Opti-spark. How many miles on your 93?
To Code 41??
