converting to 92Fbody 730 ECM MAP system. Q about VSS
Old May 15, 2003 | 11:07 PM
Fast_vette89's Avatar
Fast_vette89
Default converting to 92Fbody 730 ECM MAP system. Q about VSS
ok, i'm wring an adapter up so i don't mess with my Factory harness on the 89 L98 Vette. Q- is, there's a few diffferent ways to wire the VSS.
A- wire up 1 wire (buffered VSS)
B- wire up like 4 different "LOW", HIGH, etc....
the 92 camaro did'nt have a digital dash like us right?? so ...what do i do?
Any idea? we have a 165 ECM just like the camaro's and i'm going over to the 730 ECM using a stock 92 Z28 Auto EPROM. (which will later get custom burned.) So what do i do?? I know on the PIN out it says that if you use the 1 wire hook up...ie buffered it requires a PROM change. (maybe that's for us Vette folks). please help here guys..... :sad:
Old May 15, 2003 | 11:39 PM
SBNova's Avatar
SBNova
Default Re: converting to 92Fbody 730 ECM MAP system. Q about VSS (Fast_vette89)
I dont know your answer but thought it was funny that we were posting very similiar questions at the same time. Good luck with yours!
Old May 16, 2003 | 02:11 AM
Fast_vette89
Default Re: converting to 92Fbody 730 ECM MAP system. Q about VSS (SBNova)
ok, did some research.... the 87-89 TPI (MAF) use 2000 pulses.
the Speed density use 4000 pulses. ok, i have like 6 wires for the VSS on my 7730 ECM to 165 ECM pin out. i got it all done except the VSS.
we have....
1- VSS Low
2- VSS Hi
3- VSS output 4000ppm
4- VSS output 2000ppm
5- Buffered VSS used "ALONE"
Any freakin idea????????????????? oh, the Buffered says... requires PROM change, Mag. VSS at 0x18 b6 for $8D Proms.
Any idea?????
Old May 16, 2003 | 11:58 AM
SBNova's Avatar
SBNova
Check the reply to my VSS/ECM question made by Driveit, theres a link to a post that has the info you want.
Old May 16, 2003 | 04:55 PM
Fast_vette89
ok, i just connected the "buffered VSS" up. I'll get the PROM changed. Jason helped me on that decision. thanks man.
To converting to 92Fbody 730 ECM MAP system. Q about VSS
