compression ratio change?
Old May 16, 2003 | 08:07 AM
sothpaw2's Avatar
sothpaw2
Default compression ratio change?
Keep in mind I know little about engines...
What would I do to change the comp. ratio of the LT1? I have the heads/
cam out now (mechanic does). Would it be something simple, like different
pushrods or something?
--I would only do this if it gives me more torque or hp (prefer torque).
Old May 16, 2003 | 08:23 AM
LD85's Avatar
LD85
Default Re: compression ratio change? (sothpaw2)
Thinner head gaskets, stock, I THINK, is .039, you could go down to a set of .029's from http://www.flatoutgaskets.com
I think you could gain @ .4 or .5., have him check for valve clearance first.
Old May 16, 2003 | 08:57 AM
okinawa86vette's Avatar
okinawa86vette
Default Re: compression ratio change? (ld85)
Check out this site. Found it while trying to figure out my friend's compression ratio of a 318 he's building. Cool to play around with the numbers and figure out what's worth it.
http://www.csgnetwork.com/compcalc.html
Chris
Old May 16, 2003 | 09:03 AM
AJR's Avatar
AJR
Default Re: compression ratio change? (okinawa86vette)
Stock head gaskets on the aluminum head is .051". As said above you can use a thinner gasket with no problem. Iron head LT1 in the Impalas used .029", available at a Chevy dealer. You should have no problem with piston to valve clearance with a stock block.
Ray
Old May 16, 2003 | 12:20 PM
sothpaw2's Avatar
sothpaw2
Default Re: compression ratio change? (AJR)
My heads man asked me to buy (and I did) impala SS, 94-95 gaskets.
Maybe this is part of why.
What are the LT1 stock dimensions (bore, stroke, etc) for that calculator,
do you know?
Old May 16, 2003 | 12:31 PM
vader86's Avatar
vader86
Gasket thickness is the way if other things are held constant, but it doesnt affect the ratio THAT much.
Increasing the combustion chamber size, and selecting a different piston are the usual ways.
But with an LT1, if you go much higher, youll be running 92+ octane forever by necessity.
LT1 is a 350 SBC, 4" bore x 3.48" crank.
I wouldnt do this to just increase power, its not going to affect it as much as you might think, while keeping the engine on pump-gas.
[Modified by vader86, 12:37 PM 5/16/2003]
Old May 16, 2003 | 05:15 PM
STL94LT1's Avatar
STL94LT1
The Impala SS head gaskets are the ones I run.
To compression ratio change?
