1996 Electric door locks just quit.
Old May 16, 2003 | 02:28 PM
MaddMaxx's Avatar
MaddMaxx
Default 1996 Electric door locks just quit.
They do not work from the remote or the interior switch on either side. Any ideas? As a side note AC air will not blow out the front vents and I am throwing a p1416 (air system bank) ....when it rains it pours.
thanks max
Old May 16, 2003 | 02:53 PM
konroh's Avatar
konroh
Default Re: 1996 Electric door locks just quit. (MaddMaxx)
did you check the fuse?
Old May 16, 2003 | 03:29 PM
MaddMaxx's Avatar
MaddMaxx
Default Re: 1996 Electric door locks just quit. (konroh)
Fuse was the culprit, for the first time it was something simple...yeah!!! Have given up on even checking simple things as it is usually something complicated on this car. 1 down 2 to go.
Old May 16, 2003 | 06:04 PM
JasonL's Avatar
JasonL
P1416 is the passenger AIR check valve (behind intake manifold, near firewall). $20.
A/C I believe you can find the fix in the archives.
To 1996 Electric door locks just quit.
