removing seat from the rails?
I see 4 bolts holding the rail to the seat, but the front 2 bolts are in the seat, with no way to really get to them. Am I suppose to rip into this?
There are 4 bolts holding the seat shell to the tracks and 4 bolts holding the tracks to the car.
To remove the seat shell from the tracks first remove the bottom seat cushion (there is a retainer under the seat towards the front). Then remove the 4 bolts holding the shell to the tracks. I just used a rachet with an extension to remove the bolts.
If this doesn't clear things up for you let me know and I will take some pics for you :cheers:
with all the crap that was under there I did not even see the clip.
The seat cusion came right out. Thanks
:cheers:
