Idea for flushing coolant sys.
Old May 17, 2003 | 11:33 AM
Strick's Avatar
Strick
Default Idea for flushing coolant sys.
I fabricated a piece that allows you to connect your garden hose to the hole where the knock sensor comes out. I bought a brass fitting that fits inside the hole and attaches to a hose. I also bought a fitting that connects the hose to a garden hose. A while ago, I bought a Prestone flush kit that had a yellow plastic drain adapter that fits into the hole where you remove the radiator cap. I attached a washing machine drain hose to it so coolant wouldn't get on the Vette. When you turn on the garden hose, the water flows into the block and through the system and out the drain adapter. When the water became clear I opened the petcock on the radiator and ran it until it became clear. I also, had the heater on so the core would get flushed, too. This beats the GM way of flushing. Oh, I forgot, I did it to both Knock sensor holes.
Just thought you guys might like this idea. :thumbs:
Old May 17, 2003 | 11:58 AM
JCAIRE2's Avatar
JCAIRE2
Default Re: Idea for flushing coolant sys. (Strick)
Yup, that's a great idea! thanks for sharing :cheers:
Old May 17, 2003 | 03:58 PM
pwrful c4's Avatar
pwrful c4
Thanks for the info I will put it to use. :steering:
Old May 17, 2003 | 04:07 PM
don hall's Avatar
don hall
Strick, submit your idea as a C4 Tech Tip so we don't lose it to the archives.... :thumbs:
Old May 18, 2003 | 11:45 AM
Strick's Avatar
Strick
Default Re: Idea for flushing coolant sys. (Oldman)
Okay, How do I do that? I have other tips as well.
Old May 18, 2003 | 11:50 AM
don hall's Avatar
don hall
I'm sending you an email...............
Old May 18, 2003 | 06:40 PM
6 speed Sid's Avatar
6 speed Sid
Does it do a complete flush with the thermostat still installed? Thanks. Sid.
Old May 18, 2003 | 07:38 PM
Strick's Avatar
Strick
Default Re: Idea for flushing coolant sys. (6 speed Sid)
Absolutely :thumbs: Oh, I forgot, I ran the engine while the water was running and my heater was on. I was doing a TB bypass and just put a garden hose to the heater core intake hose, but the water came out clear. The whole idea was the connection at the knock sensors.
[Modified by Strick, 10:02 PM 5/18/2003]
To Idea for flushing coolant sys.
