FX3 codes
Old May 18, 2003 | 06:55 PM
DocToss's Avatar
DocToss
Default FX3 codes
Well I finally was able to pull the codes: 14,31,32,33,and 34. 31,32,33,34 are just out of position codes and 14 is a right front inoperative. I tried to feel the motor on the left front and right front, but could not feel any movement.Am I to assume that the right front is broken and the others are out of position secondary to this? Thanks, Tom :confused:
Old May 18, 2003 | 08:46 PM
1MoorTym's Avatar
1MoorTym
Default Re: FX3 codes (DocToss)
:nonod: Each actuator operates and is independent of the others. One being out of position or slow to reacte does not affect the others.
Old May 18, 2003 | 09:50 PM
DocToss's Avatar
DocToss
Default Re: FX3 codes (1MoorTym)
What do these codes mean to you? Or should I not ask?
Old May 18, 2003 | 10:06 PM
CanadaVette's Avatar
CanadaVette
Old May 19, 2003 | 01:05 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
Out of position codes are triggered if the computer senses that the actuator has not found the end stop position on the shock. Remove actuator at the indicated shock. Turn the valve gear on the shock stops after about 3 / 4 of turn, then you have a bad actuator. If it spins around continuously then it is a bad shock
41 = Selective ride control switch short to voltage
42 = Selective ride control switch open contacts
You can have a code 42 if you leave the switch in between indented positions
43 = selective ride control switch circuit open.
To FX3 codes
