ZF clutch HELP
Old May 18, 2003 | 07:42 PM
Stingray1970's Avatar
Stingray1970
Default ZF clutch HELP
Need suggestion on the removal of the driveline support beam. Have bolts out, but it doesn't want to come out. It appears that it has to slide to the front or rear to come free. Any suggestions would be appreciated. This whole job has been fighting me. Thanks in advance.
Old May 18, 2003 | 08:25 PM
bogus's Avatar
bogus
Default Re: ZF clutch HELP (Stingray1970)
I thought it just rolled out???
Old May 18, 2003 | 10:18 PM
Tony.96LT4's Avatar
Tony.96LT4
Try this.
http://www.zfdoc.com/transmission.htm
Also if you push the tranny to the drivers side it should allow you to roll that sucker out. :smash:
[Modified by Tony.96LT4, 9:18 PM 5/18/2003]
[Modified by Tony.96LT4, 9:20 PM 5/18/2003]
Old May 19, 2003 | 05:40 AM
pablocruise's Avatar
pablocruise
Vary the engine/tranny height in relation to the dana with the jack till there is least amount of tension on the beam while tapping on it with a BFH toward the front of car and or pass side tunnel.
Just curious, what kinda clutch/flywheel ya gonna run?
[Modified by 89 Paul in Cal, 2:42 AM 5/19/2003]
Old May 19, 2003 | 07:53 AM
Strick's Avatar
Strick
I know this may be too simple, but you did support the transmission with a suitable jack? If not, there will be too much preasure on the beam and if you do get it out without supporting the tranny, it may hurt! :blueangel:
:flag :flag :flag
Old May 19, 2003 | 09:36 PM
Stingray1970
Thanks to everyone for your help. Got the beam and the transmission out tonight, WHEW. Bellhousing, clutch and flywheel tomorrow.
Thanks again,
Gene
Old May 19, 2003 | 11:48 PM
bogus's Avatar
bogus
glad to hear it!
you may wanna consider the beam plates that Bill sells (www.zfdoc.com).
I have them, and they are great! kills the rear end of its desire to pull right on hard acceloration.
Old May 20, 2003 | 06:01 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: ZF clutch HELP (bogus)
FWIW, I just use a mallet and move the torque beam back over the differential and leave it up there when I yank my tranny. Just support the tranny prior to the banging and cover you ears.
Old May 22, 2003 | 07:55 AM
Stingray1970
Thanks for the tip on the beam plates ( didn't know they existed ). Ordered them yesterday.
Thanks again,
Gene
To ZF clutch HELP
