My car is still having problems starting when hot...
Old May 20, 2003 | 03:52 PM
Sal Collaziano's Avatar
Sal Collaziano
Default My car is still having problems starting when hot...
Ya know.. We've had our first two hot days here since I got my car back from Corvettes Unlimited.. They said the injectors are fine. BUT - my car still has trouble starting when it's hot.
The started engages with no problem, but it turns over for awhile before it "ignites". What could be the problem? I get a nice BIG puff of white smoke when it eventually starts...
When cold, it starts instantly.. No problem at all...
Oh, let me throw in one other question. Occasionally - I smell antifreeze... Why occasionally?
Thanks...
Old May 20, 2003 | 04:20 PM
Vic'89's Avatar
Vic'89
Default Re: My car is still having problems starting when hot... (Sal Collaziano)
It's an 87 , right ?
Did they replace the cold start injector ? It could be leaking and causing a hot start issue, I had this happen on my old Irocz.
Vic
Old May 20, 2003 | 04:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I think Vic is right; you might have a problem with the 9th injector or it's control circuit (it isn't controlled by the ECM).
Also you could put a fuel pressure gauge onto the Schraeder to check leakdown rate.
If you smell coolant occasionally it's getting out somewhere. Check under the wate pump and around the lower hoses. But that "big puff of white smoke" doean't sound good. You may need to do a radiator check to see if there is excessive pressure buildup with the engine running. Or it could be due to coolant leakage into the valley.
[Modified by 65Z01, 4:26 PM 5/20/2003]
Old May 20, 2003 | 04:25 PM
Sal Collaziano
Default Re: My car is still having problems starting when hot... (Vic'89)
Yes, an '87.. I'll have to ask if they changed that. I never heard of it... Thank you...
Old May 20, 2003 | 05:02 PM
J Z06's Avatar
J Z06
Join the friggin' club dude!
Ever since the DFI went in, my car starts hot like a bag of sheeot! :rolleyes:
I am just dealing with it for now. Cold starts are amazing. It's just a matter of tuning.
Old May 20, 2003 | 05:12 PM
ZR1 Jim's Avatar
ZR1 Jim
Sal, I am having the exact same problem with my '87. It roars to life when cold but is really difficult to start when hot. Sometimes it stalls and idles poorly when hot also. I am going to check the ignition module and the IAC. Hopefully I will have time this week. I will report back here with the results.
Old May 20, 2003 | 11:15 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It sounds like its flooding. Most likely still injector leakage. But since they serviced the others, it has to be this one.
I think I recall on your invoice they charged you $20 for a cold start injector oring, but didn't change the injector itself. They may have checked it though, if they removed it. TLD has it listed for $40 BTW.
Old May 21, 2003 | 01:45 AM
Sal Collaziano
Default Re: My car is still having problems starting when hot... (CentralCoaster)
They supposably checked my injectors - but I don't know.. If I hold the gas pedal all the way down, it'll start right up... Otherwise, I have a problem when it's hot...
Old May 21, 2003 | 09:58 AM
Vic'89's Avatar
Vic'89
I bet it's the cold start injector.
Vic
Old May 21, 2003 | 10:24 AM
doc's toy's Avatar
doc's toy
Mine floods hot but starts good cold,I smell fuel on hot restart,but have no smoke,if you have MAF that could be your problem as they always fail more or are irratic hot,at least thats the way it was when I was at the dealership,they always said if its black its bad
To My car is still having problems starting when hot...
