tts datamaster run, my first :)
Old May 20, 2003 | 07:18 PM
devilfish's Avatar
devilfish
Default tts datamaster run, my first :)
I know this belong in the scan section. But I post it here also..
Hooked up my laptop and made a few runs.
I never reeved abow 3000rpm.
This is my first scan.
Feedback please?
Download it here..
http://stalblom.datakultur.com/webpage/DD.uni
Old May 20, 2003 | 07:48 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: tts datamaster run, my first :) (devilfish)
Congrats Devilfish!! :) I'll take a look later tonight on my scanning laptop..
Old May 20, 2003 | 07:52 PM
Nathan Plemons's Avatar
Nathan Plemons
I was gonna look at it too but I don't have that version of the software installed, and I'm too lazy to go find my CD. Maybe after dinner, right now my bed is just too comfy.
Old May 20, 2003 | 07:56 PM
devilfish's Avatar
devilfish
Default Re: tts datamaster run, my first :) (Nathan Plemons)
I understand.
I will make som new runs tomorow. Im going to take it to 5000rpm. And coast alot.
I will try to install the new BETA datamaster. I think that is the software you use Nathan?
Please tell me how to make good logging runs :)
Old May 20, 2003 | 08:22 PM
Timmy!'s Avatar
Timmy!
Hmmmm - your file displays some strange #'s, almost like it's not reporting the #'s in the right places. For instance it's showing that you are running a 1000% Duty Cycle on your fuel injectors - probably not possible. Actually almost nothing is showing up correctly for me. Which version of Datamaster were you using?
Old May 20, 2003 | 08:49 PM
Nathan Plemons
I'm runing version 3.4.1
Timmy, this is what happens to me when I tried to open the file but it's not really the version that's the issue, it's the format. I use the DA version because that's the type of computer I have. I also have the EE version installed, which is for newer PCM's. Apparently it will open the file but it won't display correctly unless you are running the right calibration of the software.
The late TPI cars use the 8D software, download and install it and you'll see proper results.
Old May 20, 2003 | 09:05 PM
Nathan Plemons
of course it doesn't matter. I download the version of the software I need to review your log and it won't run on my laptop. The DA and EE versions run just fine, but the 8D version just crashes.
Old May 21, 2003 | 04:28 AM
devilfish's Avatar
devilfish
thats strange ?? damn! Just when you thought you where getting somewhere...
Old May 21, 2003 | 04:32 AM
devilfish's Avatar
devilfish
I use datamaster 32 3.4.11 BETA version...
Old May 21, 2003 | 09:07 AM
Nathan Plemons
The only beta version I see available on the website is version 3.4.11 which is for 94-95 cars
Then I see a bete 3.4.8 for 86-89 TPI cars
:confused:
To tts datamaster run, my first :)
