89 6 speed problem
Old May 20, 2003 | 09:35 PM
chuck89's Avatar
chuck89
Default 89 6 speed problem
this problem is when i shift in to 1st it is perfect but when i try to shift it down into 2nd its pretty hard to put it in the gear but when i jiggle it a little it goes in fine it also grind sometimes what can the problem be should i not put in the clutch all the way down please help thankyou.
Old May 20, 2003 | 10:44 PM
don hall's Avatar
don hall
Default Re: 89 6 speed problem (chuck89)
You might try disconnecting the 1-4 lockout connector on the side of the tranny (if you haven't already) and see if that makes a difference. If that solves your problem, tape the ends of the connector to prevent corrosion, or you can purchase a coupler.
Old May 20, 2003 | 11:49 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: 89 6 speed problem (Oldman)
You might check fluid level too in the tranny and clutch master cyl.
I use the GM fluid,others go redline,YOU DECIDE!!!!
Matt
To 89 6 speed problem
