Code 34 - Any Suggestions?
Old May 20, 2003 | 10:33 PM
c4md's Avatar
c4md
Default Code 34 - Any Suggestions?
Got a Code 34 - MAP (Low voltage, High vacuum) and the car runs like crap. Seems like there can be a lot of causes other than replacing the MAP sensor. Anything common that I should check first? :confused:
Old May 20, 2003 | 11:01 PM
don hall's Avatar
don hall
Default Re: Code 34 - Any Suggestions? (c4md)
Besides the specified voltages checks for intermittent circuit opens, the ECM should also be considered as suspect.
Old May 21, 2003 | 12:03 AM
vader86's Avatar
vader86
Replace the MAP sensor. Check for vacuum leaks.
To Code 34 - Any Suggestions?
