Brake warning light acting weird
Old May 21, 2003 | 02:07 PM
tapper's Avatar
tapper
Default Brake warning light acting weird
The brake warning light flashes one or two seconds, only when I turn right! :confused:
And it seems that it only flashes when I NOT apply the brakes...
Fluid level is OK, parking brake warning function also OK, ABS OK.
I disconnected the battery to "clean" the ECM. No different.
Everything feels allright... any ideas?
Old May 22, 2003 | 12:57 PM
tapper's Avatar
tapper
Default Re: Brake warning light acting weird (tapper)
ttt
Old May 22, 2003 | 01:04 PM
SunCr's Avatar
SunCr
Check the harness and the connector at the master cylinder.
Old May 22, 2003 | 05:06 PM
tapper's Avatar
tapper
Default Re: Brake warning light acting weird (SunCr)
Thanks. I`ll check that. This is really weird... if I stand still and turn right, no light. A slow turn, no light. A quick turn, or a long curve with speed, the light goes on. When the curve straightens, the light goes out.
To Brake warning light acting weird
