A long time ago, I got in the habit of blipping the throttle just before switching the engine off, something I picked up from hot-rodders I hung with.
I thought the idea was to clean the plugs before shutdown, but most of those cars were carbureted so they actually would have been tossing in a slug of fuel and then killing the ignition which seems like it would leave the pistons/plugs wet and do more harm than good, so I have no idea what that was accomplishing.
Conversely, on a FI motor, would it make any sense to nail it and switch off the ignition at 1500-2000rpm and hold the throttle open while the motor spins down, essentially pumping dry air through for a few cycles, or is this just a bad idea all the way around?
Even for a carbureted engine the idea of "blipping" the throttle is a poor one.
Even after a very hard run the best thing to do is let the engine idle for a moment or so and then shut it off. The idea is to gain some temperature stabilization/equilibrium for the whole system.
My dad used to do it on our old '78 Malibu. He said that it was good to do because it kept some of the cylinders full of fuel so that it would make it easier to start the car later. Not that it ever had a problem starting - it had a low-revving 305. It was bullet proof.
But as it turns out it was a detrimental thing to do. And the same holds true for our cars - fuel injected or not.
I wouldn't do it. The best thing to do is let it idle a bit (30sec max). On a Turbo charged car it's recommended you let it idle for a few minutes if you've been driving hard to cool the turbo bearings, but other than that, shut it down.
