Block Learn w/ 24# injectors?
Old May 22, 2003 | 02:22 PM
Klamath Stoogie's Avatar
Klamath Stoogie
Default Block Learn w/ 24# injectors?
Approximately what should my block learn be if my only change from my stock 1991 L98 is 24# svo injectors?
Before I put the svo injectors in, my block learn was around 108-118 or so. One of my stock injectors was only 9 ohms so I decided to replace them all with the svo's. Now I'm not sure what to use as a "baseline" to see if I have corrected whatever was causing my rich-indicated condition.
[Modified by Klamath Stoogie, 7:23 PM 5/22/2003]
Old May 22, 2003 | 02:25 PM
GRX's Avatar
GRX
Default Re: Block Learn w/ 24# injectors? (Klamath Stoogie)
Better in Scan and Tune section...
Old May 22, 2003 | 02:26 PM
Klamath Stoogie
Default Re: Block Learn w/ 24# injectors? (GRX)
Ok, I'll post it over there, thx.
To Block Learn w/ 24# injectors?
