Antenna
Old May 24, 2003 | 05:26 AM
Dudule's Avatar
Dudule
Default Antenna
I've received a new antenna ( the whole stuff) for my 92 and I'd like to know if it's easy to replace by myself and if so, how to do it?
Thanks for your help....
Old May 24, 2003 | 07:37 AM
Skippy Stone's Avatar
Skippy Stone
Default Re: Antenna (Dudule)
It's so easy, you don't even need a shop manual. Which you should get, IMO. Take the old one out. (The connector is inside the back of the car) AND remember what you did. Put the new one in reverse of what you took out. If you don't want to buy a shop manual, then do a search here and see if there is more information.
Old May 24, 2003 | 08:51 AM
Dudule's Avatar
Dudule
Default Re: Antenna (Skippy Stone)
Thks for your reply Skipping Stone, but the problem I've got is that the old one is already out, I've had it out by a mechanics... And as I'd like to put the new one by myself I need some assistance !
First of all is it mandatory to take the rear bumper off to have access to the place of the antenna?
Greg
Old May 24, 2003 | 09:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Pop the wheel off
remove inner wheel well
Now you can see where to mount bracket. You will have to stick you arm up between all the crap to get to the underside of the rear deck.Spin the big plastic nut onto the threaded bezel.The connections are under the trim in the middle of the cargo area. :cheers:
Old May 24, 2003 | 11:04 AM
DocToss's Avatar
DocToss
Default Re: Antenna (AGENT 86)
My 92 did not have a plastic nut to spin, just a gasket to push the antenna base through. Are you replacing the whole motor or just the antenna?
Old May 24, 2003 | 11:05 AM
DocToss's Avatar
DocToss
Default Re: Antenna (DocToss)
I did not have to take the tire off to get to mine, but it was a tight squeeze.
Old May 24, 2003 | 11:19 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
If it is GM then you will have no problems. If not GM then you may not match up regarding antenna cable ends and power wire colors.
I believe there is a tech tip on this project. I did mine with an aftermarket unit last year. About a 2-3 hour job, but I work real slow and take lots of breaks. On my 91 I had to remove the license plate to remove the two taillight assemblies to get to the antenna wiring. I think I followed a tech tip here on the forum.
Good Luck! :yesnod:
Old May 24, 2003 | 12:54 PM
DocToss's Avatar
DocToss
Default Re: Antenna (brdd)
I also had to remove the license plate and two light assemblies to get at the motor. Not hard, just tedious.
Old May 24, 2003 | 02:24 PM
hngacurv's Avatar
hngacurv
If you have long skinny arms you can reach the bezel from underneath the rear of the car. If your arms are shorter like mine you'll have to remove the rear wheel and fender well. Either way its pretty simple.
To Antenna
