no power
Old May 27, 2003 | 11:49 AM
jtfrog's Avatar
jtfrog
Default no power
When I turn the key my car looses total power, no lights nothing at all. If i wait a couple of minutes power comes back. Sometimes it starts and somtines it looses power agian? :confused:
Old May 27, 2003 | 11:56 AM
rocketfinger's Avatar
rocketfinger
Default Re: no power (jtfrog)
I've seen bad battery connections do this, corroded connections or cables can effectively become a resistor which heats up and becomes an open circuit. Once it cools/contracts/whatever it conducts again.
Old May 27, 2003 | 12:05 PM
jtfrog's Avatar
jtfrog
Default Re: no power (rocketfinger)
Teminals appear to be clean wuth no signs of corrotion
Old May 27, 2003 | 12:15 PM
John Row's Avatar
John Row
How old is the battery? Could have some dead cells. What is the voltage with the key off? With the key on?
Are you sure the alternator is supplying enough current to charge the battery.
Is the belt slipping? How old is your serpentine belt? Is the tensioner supplying enough tension?
These are the simple things.
Old May 27, 2003 | 12:32 PM
rocketfinger
Default Re: no power (John Row)
That's another one than can drive you nuts. If the plates are flopping around in the battery, doesn't work, now it does again, hit a bump...fade to black.
Old May 27, 2003 | 01:17 PM
jtfrog's Avatar
jtfrog
i dont know how old the battery is. The alternator is new and putting out 13.8 volts give or take. The battery puts out about 12.4 volts with car not running
Old May 27, 2003 | 01:33 PM
John Row's Avatar
John Row
I'd start with a new battery. It's easy to replace and only costs you $40-$60. When you are trouble shooting electrical problems, you need to know where you are starting. It may not fix the problem, but it does eliminate an unknown.
If don't want to do the battery, find a good automotive electrical shop, take the battery and the alternator to them for testing. That'll probably cost you $20-$25.
Even if the terminals look clean, pull them and clean them anyway. While they are off the battery, be sure the connection to the starter is tight. It's one thing to put out voltage, it's another to actually move the necessary amps.
I don't know where your grounds are, but follow the wires and make sure they are tight.
Old May 27, 2003 | 01:42 PM
jtfrog's Avatar
jtfrog
the battery is a gel type if it makes any difference
Old May 27, 2003 | 02:05 PM
John Row's Avatar
John Row
No personal experience with them. Some people love them, some people hate them.
It's not likely that loose plates are a problem, but I suppose it could still be bad. They are expensive, so maybe have it checked before tossing it.
Old May 27, 2003 | 02:36 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Clean and tighten your battery cables.
There is a ground running to the frame under the battery (actually more under the brake booster) that will corrode and lose contact. Clean that up if the terminal clean doesn't fix the problem. Note: You will have to remove the battery and the battery box to get to this ground.
Old May 27, 2003 | 03:10 PM
jtfrog's Avatar
jtfrog
could this have anything to do with the vats
To no power
