Ticking noise??
Old May 27, 2003 | 01:43 PM
Fast_vette89's Avatar
Fast_vette89
Default Ticking noise??
started making a ticking noise from the driver side valve cover area. under a load... and now more and more. sounds like that valve tick you get when your low on oil. Sound familiar? L98.
Old May 27, 2003 | 02:44 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: Ticking noise?? (Fast_vette89)
It's either a collapsed lifter or a rocker arm adjusting nut that's backing off - have you had the engine apart in the last little while?
My engine is ticking now and it gets louder as load/RPM increases. But I had the engine apart to change my head gaskets. I followed GMs suggested procedure to set my lifter preload, but for some reason I have to adjust my valve lash. Maybe it's the same in your case.
If you haven't had the engine apart in the last while, it's probably a collapsed or bad lifter. I'd suggest a quick engine flush to see if it solves the problem. Sometimes sludge gets into the lifter oil hole and it can keep it from 'plumping' up as oil pressure rises - an engine flush should clear that out if it is indeed the problem. If not, then you may have to replace one or more lifters.
[Modified by TheCorvetteKid, 7:48 PM 5/27/2003]
Old May 27, 2003 | 03:11 PM
vader86's Avatar
vader86
Sounds like a weak lifter to me, hopefully its not a real problem yet. You can add some more oil and see if it goes away.
But if you do get time, take off the valve covers and look around.
Old May 27, 2003 | 03:14 PM
VMAX451's Avatar
VMAX451
If it only happens under load, it sounds like an exhaust leak. A lifter tick would not usually be dependent on load, only rpm/oil pressure. Check around your exhaust manifold: gasket, bolts, emissions connections, etc. Any leak there could easily sound like it's coming from the valve cover.
Old May 27, 2003 | 03:25 PM
Fast_vette89
Default Re: Ticking noise?? (Vince Ivanc)
makes sense... probly is. F'n headers. I also think/know the alternator bearings are going... GREAT all in the same area.... nice for diagnostics. not.
Old May 27, 2003 | 04:38 PM
Half Fast's Avatar
Half Fast
:iagree:
A lifter will be most noticeable at startup. An exhaust leak sounds like what you're describing. A mechanics stethoscope will really help pinpoint those kinds of noises.
To Ticking noise??
