Low oil light
Old May 29, 2003 | 10:17 AM
devilfish's Avatar
devilfish
Default Low oil light
my "low oil light" comes on time to time. But I have plenty of oil left when I check it with my dip stick. Possibly short in the censor?
Old May 29, 2003 | 10:25 AM
kittmaster's Avatar
kittmaster
Default Re: Low oil light (devilfish)
that would be my guess or something is chaffing the wire to gnd sending a false signal. Have you done any work in that area?? Double check, try cleaning the connector contacts..
Old May 29, 2003 | 11:45 AM
devilfish's Avatar
devilfish
Default Re: Low oil light (kittmaster)
yep I done work in that area. And I even broke some gnd points, I rewired those. God point I will check that out. But its only the" low oil" light that makes trobule hmm?
Old May 29, 2003 | 12:18 PM
tdock's Avatar
tdock
I would get a "low oil" on the digital oil temperature readout, on a cold morning, like below 32 degrees, checked the oil level and it was good. Figured it was just below the temperature range of the sensor.
Old May 29, 2003 | 01:55 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Low oil light (tdock)
I had a problem with mine showing the low oil light from time to time when I know i have plenty of oil in it. Changed the sensor in the pan and do not have the problems anymore.
To Low oil light
