Strange sound when braking..
Old May 29, 2003 | 10:19 AM
devilfish's Avatar
devilfish
Default Strange sound when braking..
Sometimes when I brake I got a strange "mumble" sound somewhere around the car. The sound continues even after I let of the brake for som time to only disapear after about 5 min of higway driving.
Got any clues?
Old May 29, 2003 | 11:35 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Strange sound when braking.. (devilfish)
It could be the ABS.
Old May 29, 2003 | 11:39 AM
devilfish's Avatar
devilfish
Default Re: Strange sound when braking.. (War Machine)
hmmm explain..
Old May 29, 2003 | 12:00 PM
War Machine
If that sound you hear comes form behind you and goes side to side and your brake pedal is stiffening up on you then it's the Anti-lock Brake System. If not, then it's some other noise I'm not familiar with.
Old May 29, 2003 | 12:13 PM
devilfish's Avatar
devilfish
ok
So your guess is normal ABS activity? OR a faulty ABS system?
Old May 29, 2003 | 12:59 PM
War Machine
There is something wrong if it's going off for 5 minutes and you're not on the brake. :yesnod:
Old May 29, 2003 | 01:40 PM
devilfish's Avatar
devilfish
It cant just be bad brake pads or something that dosent let go of the disc after I brake?
To Strange sound when braking..
