100 Octane in LT4
[Modified by ScottsLT1, 3:29 PM 5/30/2003]
:iagree: I get this all the time and always go and find all the research to back it up to end the argument. Bottom line 93 octane is the most I would run in any Vette unless you are running something like a 500+hp motor. If you run 100 octane you are doing more damage then good.
Other than that, if your car still has the stock compression ratio, it's not an advantage except in high summer heat. It'll help a hot engine.
Go to Union 76, Sunoco, etcs websites, they all have great technical articles about their racing fuels. And you can construct a dilution table for your C4 figuring in our 20 gallon gas tanks.
50/50 mix - 93 * (10/20) + 100 (10/20) = 96.5 octane
25/75 mix - 93 * (15/20) + 100 (5/20) = 94.8 octane
I think in some places you can get Sunoco 94 out of the pump, so you can see that there isn't big economics in running race fuel in cars with pump-gas compression and no forced induction.
[Modified by Matt Black, 7:22 PM 5/31/2003]
I have tried a mix of 100/91 when I went to the track and could find no difference. Bottom line is save your money.
:eek:
:eek:
